Closed Thread
  #141
Old 04-05-2012, 06:42 PM
zion zion is offline
Default Re: new pro tools is not as good
Originally Posted by mightyduck View Post
Well, I'm sure you can see that a lot of that is double-speak and cya. They still don't come out and say what they mean by 64-bit compatible.
Anyhow, personally I think a lot of the decisions were made in favor of increasing track count. That's what they're on about, and that's what a lot of users probably want. More tracks. So that's what they are concentrating on.
The more track count the more gain (volume), thats what they are referring to here. Thats were a 32bit float and 64bit float mixer summing going to come into play here in a major way. As well as a better sound quality.
"Quote A 64-bit floating-point mix bus provides more than 1,000 dB of headroom, which is more than enough to handle the huge track counts that Pro Tools|HDX can deliver"
  #142
Old 04-05-2012, 06:54 PM
We created AAX for the future, as it's a 64-bit (ready) format
  #143
Old 04-05-2012, 06:55 PM
mightyduck mightyduck is offline
They're trying to say that the 64 bit summing bus will allow a larger track count. But that's a red herring, because its still going to have to fit onto a 24 bit fixed path for output. And that's where it may get weird.
Not with what they are doing.
  #144
Old 04-05-2012, 06:56 PM
Emcha_audio's Avatar
AAX is 64 bit ready. It's not a may or may not, they are.
Manny.
Wave-T.com
  #145
Old 04-05-2012, 06:57 PM
What is your point?
64 bit what?
  #146
Old 04-05-2012, 06:58 PM
What is your point?
64 bit what?
Memory access 64 bit ready. I doubt well see the engine (as in floating points through and through) change soon, it's taken long enough for it to evolved to what it is now.
Manny.
Wave-T.com
  #147
Old 04-05-2012, 07:03 PM
Right, I don't know that there will be much in the way of 64 bit [double precision] aax or rtas plugins, if past is prologue, and given that the bus is 32 bit float.
Who knows. 64 bit app. will kick butt for virtual instruments and stuff, though.
  #148
Old 04-05-2012, 07:07 PM
What is your point?
64 bit what?
TDM has no future in the 64bit world. The bottom line is it ends here at
Pro Tools 10 software.
  #149
Old 04-06-2012, 04:27 PM
Avid's Avatar
Avid Avid is offline
Administrator
Post Re: new pro tools is not as good
Some clarification from Engineering:
The progression to a 64-bit app has nothing to do with the mixing DSP, only with the memory space/OS used (and it breaks compatibility with older code including plug-ins).
We have no plans currently to change the mixing structure in HDX (or Native) – it is very similar to TDM systems in that the internal mixing is done to a 64-bit floating point accumulator (even if a mix bus spans DSP chips, similar to how a TDM system will keep a 48-bit fixed point mix bus across DSP chips). There are no cases in a TDM system where we keep 48-bits but don’t keep 64-bit floating point in the HDX system.
Floating point is more convenient for programmers, but it also has some cool advantages. Gain stages don't strongly affect precision. You can gain something down by 60dB (for example) and back up again with no loss in precision. That is where the dynamic range comes into play. Depending on the actual number, you could have some rounding in the lowest bits, but nowhere near the potential signal loss of fixed. This allows you to be a little more care-free with gain-staging. Single Precision floating point does have some disadvantage in precision compared with 32 bit integer, but it has no precision downsides that I'm aware of compared with 24 bit integer. In all places where we need a lot of precision, we have converted to double precision floating point. Double precision floating point, which is what we converted the 48 bit parts to, actually has 52 bits of precision along with the increased dynamic range, so it is clearly better in all regards.
Dither is indeed a different beast with floating point – a fixed-level dither signal doesn’t “smooth out” quantization distortion like fixed-point dither does. That said, there are several dither plug-ins available which provide the right level of dither such that the eventual quantization to 24/20/16 bit is properly “smoothed.”
Avid Engineering
Administrator
Closed Thread
I'm so good at Pro Tools ianbee Pro Tools 10 64 10-13-2013 01:24 PM
003 only good for Pro Tools? ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-28-2010 07:22 PM
Good PC for Pro Tools? Under £600 pezking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-03-2009 04:28 AM
New Mac..Is it good with Pro tools?? gstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-05-2009 09:42 AM
Good PSU for Pro Tools PC SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-01-2009 10:36 AM
