#51
Re: Manual Delay Comp Problem
I believe 1 sample offset is correct for digi interfaces. Theoretically you cannot be reading and writing the same sample at once, hence the 1 sample delay.
The problem is difficult to explain and many people are totally unaware that it happens. FYI. Once you've recorded an overdub, you can change the "user offset" delay at the bottom of mix view strips to -X where X is you offset and all will line up on playback. In my case, its -72. Don't forget to change it back to 0 before recording on that track again - or you offset will get worse. Negative values push the wav file back when recording. Kinda like what we're asking for - but in the opposite direction! |
#52
-Dan |
#53
excellent. Thats dealt with then.
#54
Cheers, Steve |
#55
Hopefully "future versions" means the next update
#56
Being that ur new around here, I will say don't get ur hopes set on that...
#57
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
#58
#59
I am also a new PT user and have grown accustomed to the ability to test my system once and set it for compensation. I run a MOTU 896HD with extra inputs coming in via ADAT. In SONAR, the app allows me to augment what is automatically determined to be the correct compensation with a manual input to reflect that actual real life need. My experience is that many people do not take the sync seriously... but I wish to have perfect sync and so this interests me greatly. When I started in DAW I thought this issue was a huge downside and was relieved greatly when SONAR provided a semi automated solution. I hope Avid can provide the function in the near future. Thank You. best regards, mike |
#60
BTW, I created a Gearslutz thread a few weeks back after doing some testing. It turns out that at default settings PT9 compensates exactly the same as Sonar and the audio ends up exactly 1 sample behind. You can see my findings along with screenshots here:
http://www.gearslutz.com/board/music...nterfaces.html Check out post #115 for the screenshots: http://www.gearslutz.com/board/6086380-post115.html |
HELP!! Bouncing-in-place by recording to new audio tracks - delay comp problem | johnnybigmoose | Pro Tools 9 | 9 | 12-31-2012 01:36 AM |
PT 10.0.0 HD Native Automation Problem with Delay Comp | Chris Trent | macOS | 5 | 01-07-2012 03:04 AM |
Delay Comp problems again, Delay comp is RED but way below limits. | soundeq | Pro Tools TDM Systems (Mac) | 13 | 11-29-2011 12:01 PM |
since cs3 intermittent UAD/Wrapped plugs delay comp problem | crizdee | Pro Tools TDM Systems (Mac) | 9 | 06-16-2009 09:12 AM |
Problem with Delay Comp. and not enough DSP/Time slots... | storm-01 | Pro Tools TDM Systems (Mac) | 0 | 08-16-2007 01:54 PM |
