Mbox 2 w/ Pro Tools 8, clicks and pops during record and playback
I recently upgraded to Pro Tools 8.0.4 to use with my Mbox 2, however, during record and playback there are clicks and pops. I am recording at a 44.1 kHz sample rate and a 24-bit bit depth.
Re: Mbox 2 w/ Pro Tools 8, clicks and pops during record and playback
What OS are you running? If its XP, I would roll back to 8.0.1cs2. 8.0.4 has shown some minor issues on WP that make it less than perfect. Now is there anything coming into the Mbox SPDIF input? If yes, then you need to choose your clock source as SPDIF.
I'm running Windows 7 64-bit. There is nothing going into my S/PDIF inputs so I have the clock source set to internal. But this has to be some kind of clock problem, right?
It could also be a USB issue. I had similar problems with the MBox 2 Mini at first, but switching USB ports solved the problem for me.
So some things to try:
All 3 of those solutions have helped in several cases of noise with the USB interfaces.
Do all that, then go here and watch the videos for Windows
http://www.youtube.com/view_play_lis...EC1AEC94DB22D6
I've disabled my computer from powering down the usb ports, and I've also tried using a different usb port. Since I don't have a powered usb hub, I can't really try that right now. The annoying clicking still remains. Getting desperate.
Try a different buffer setting. Did any other version of PT work on your computer? If yes, go back to that version. If no, post a Sandra report as someone may be able to spot a hardware issue.
It's pretty much a brand new computer. Would the buffer setting make a difference? The clicks and pops are there even when I'm in record-ready.
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC. The more information you can provide, the easier it will be for Tech Support and other users to assist you - take the time now to document everything you can and you'll save time in the long run. We can't express enough the importance of describing everything in extreme detail - remember, no one here can see how your gear is configured, so we need an accurate description by you to get a clear picture. The better we can envision your setup, the easier it will be to troubleshoot.
SiSoftware Sandra
Computer Model : Asus G73Jh Processor Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz Speed : 1.85GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Asus G73Jh BIOS : AMI G73Jh.204 01/11/2010 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DDR3 SO-DIMM Chipset Model : ASUS Clarksfield/Lynnfield DMI Front Side Bus Speed : 2x 2.56GHz (5.11GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.27GHz (4.54GHz) Total Memory : 6GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 710MHz (1.42GHz) Memory Module(s) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Mobility Radeon HD 5870 (720 SM5.0 700MHz, 1GB DDR5 2x1GHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Mobility Radeon HD 5870 (800SP 10C 700MHz, 1GB 2x1GHz) Compute Shader Processor : ATI Mobility Radeon HD 5870 (720SP 700MHz, 1012.7MB 2x1GHz) Storage Devices Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) Seagate ST3400632A (400GB, USB/ATA, 3.5") : 373GB (D:) HL-DT-STDVDRAM GT30N (SATA150, DVD+-RW, CD-RW, 1MB Cache, 192kB Flash) : N/A (E:) Logical Storage Devices OS (C:) : 446GB (NTFS) @ Seagate ST9500420AS (500.1GB, SATA300, 2.5", 7200rpm, NCQ, 16MB Cache) SEA_DISK (D:) : 373GB (NTFS) @ Seagate ST3400632A (400GB, USB/ATA, 3.5") Optical Drive (E:) : N/A @ HL-DT-STDVDRAM GT30N (SATA150, DVD+-RW, CD-RW, 1MB Cache, 192kB Flash) Peripherals LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Audio Device : ASUS EG JUNIPER XT Audio Device [Radeon HD 5700 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Photosmart C7200 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11n (HT), AES-CCMP, 65Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 99% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Clicks and Pops During Playback and Record (Not a Buffer Issue) | SamRisen | Windows | 10 | 11-11-2013 05:44 AM |
Mbox (regular) 3rd gen with pt9 playback pops and clicks | jonnystrides | FireWire & USB Audio Interfaces (Win) | 12 | 05-01-2013 08:24 AM |
Clicks and Pops During Record But Only Heard on Playback | jrtme | Pro Tools TDM Systems (Mac) | 9 | 12-09-2009 08:17 AM |
HELLLP!!! Clicks and pops Durring playback and Record but not at Bounce! | PRS2300 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-05-2009 03:07 PM |
audible pops and clicks on playback/pt 6.4/mbox | chunkymutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2006 05:25 PM |
