Old 12-04-2009, 08:47 PM
pkmag2 pkmag2 is offline
Default Firewire 800 -> 400 Converter cable
hello all,
anyone able to inform me which cable is required for connecting to the imac to the 002r? I've noticed that there are 9-6 and 9-4 pin cables and i've searched the duc numerous times and havent found anything conclusive, just the fact to go get a 800 to 400 cable.
thanks
paul.
Old 12-04-2009, 09:02 PM
nozzles nozzles is offline
Default Re: Firewire 800 -> 400 Converter cable
9 - 6 pin cable.
'hope that helps
Old 12-04-2009, 09:30 PM
The Apple store sells a Belkin adapter cable that works fine. OWC www.macsales.com also has an inexpensive adapter cable that works.
Note: You should also get a firewire drive if you're planning on using Protools. It is required to use two hard drive and since the iMac only has one drive internally, you need an external firewire drive (not USB as it is not supported).
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-04-2009, 10:46 PM
thanks for the info.
def. will be getting external fw drive down the track.
Mbox Pro Firewire to USB Converter DJ Hero FireWire & USB Audio Interfaces (Win) 3 05-17-2013 06:20 AM
switching from USB cable to Firewire cable moonwalker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-02-2009 08:21 AM
Firewire to Serial ATA Converter? Armando Pro Tools TDM Systems (Mac) 2 02-27-2004 02:37 PM
firewire dv converter? friendlybunny Post - Surround - Video 2 06-03-2003 11:58 AM
Anyone using FireWire to SCSI converter? beatboy Pro Tools TDM Systems (Mac) 2 12-20-2002 07:15 AM
