Old 06-23-2009, 04:44 PM
gearhead2010 gearhead2010 is offline
Exclamation ProControl Fader Dead
Hi all,
If I move the fader on screen with my mouse, the PC fader does not move.
If I move the PC fader, the fader in PT does not move.
All the others work fine.
Anyone here have any suggestions on how to fix?
I tried the tests, reset and calibration features found in the Utilities section, but no go.
I live in NY and if anyone has a resources for a replacement fader or repair I would appreciate it.
I called the NY repair center listed on the Digi site, but they seemed not to sharp.
Many thanks...
Old 06-25-2009, 10:26 AM
Niels B Niels B is offline
Default Re: ProControl Fader Dead
Have you tried to disconnect the power for 10 sec?
Old 06-29-2009, 05:34 PM
MELOSAGE MELOSAGE is offline
yes a thousand time and still the same, sometimes it come back for about 2min and the fader slam up and down.
Old 06-29-2009, 05:54 PM
Craig F Craig F is offline
have you open up the unit (the panel just lifts up) and tried reseating the connector?
Thank you,
Craig
Old 06-30-2009, 01:00 AM
i open it up and remove the power supply, and also made sure all the connector and tight, putting it back together right now, fingers are cross.
Still the same thing,
Old 07-14-2009, 09:51 PM
blackmacdaddy blackmacdaddy is offline
Go to Utility > Test > Fader > Recal button
...and press it about 1000 times.
A pulse perhaps?
Best!
W
It's only R'n'R but I like it.
Old 08-24-2009, 03:20 AM
edemunari edemunari is offline
Angry Re: ProControl Fader Dead
Any help addendum about how to open the PT and check the fader, i got the same problem on my own.
Where are located the right screw? don't wanna to take all apart before finding the right ones.
All the best.
Eriberto
Ciao
Eriberto
Old 08-24-2009, 07:17 PM
there are 4 or 6 screws around the perimeter of the plate the faders are mounted to
remove those and lift the plate
Thank you,
Craig
Old 08-25-2009, 10:51 AM
The screws are 14...
but are the right ones!!! Thanks, now my fader is repaired... all was due to a broken rubber belt!!! i repaired it with a lot of lucky... anyone knows where to get them so you don't have to substitute all the fader...
Thanks a lot, Eriberto
Ciao
Eriberto
Old 08-25-2009, 07:24 PM
4, 14 so I was off
I have gotten replacement faders from Digi
Probably best to contact the closest Field Service Engineer and ask him how much
Thank you,
Craig
Dead ProControl Main Unit Jim Roberts ProControl, Control|24, Command|8 18 08-10-2012 08:29 AM
'Fader Pack' and ProControl Fader order issue Ciaran ProControl, Control|24, Command|8 2 03-21-2005 11:58 PM
Is Procontrol "DEAD" Hostage ICON & C|24 10 03-07-2005 05:59 PM
Dead Fader on Fader Pack engineerjoel ProControl, Control|24, Command|8 4 08-28-2003 11:05 AM
Shuttle dead on ProControl! Helgonet Pro Tools TDM Systems (Mac) 8 07-26-2003 12:27 AM
