Old 06-11-2009, 09:54 AM
crizdee's Avatar
crizdee crizdee is offline
Default since cs3 intermittent UAD/Wrapped plugs delay comp problem
With cs3 when inserting a wrapped plugin or UAD plugs etc the delay compensation doesn't always work and doesn't display any reading in the DC window. I have to de-activate then re-activate the plugin for it to work
This has happened 4-5 times since yesterday with UAD
UAD 5.3
Producer, Engineer,
www.ukmastering.com
Old 06-11-2009, 03:55 PM
gonzolagonda gonzolagonda is offline
Default Re: since cs3 intermittent UAD/Wrapped plugs delay comp problem
I keep getting weird different audible Left-Right/Overall delays going on when tracking (using a master Aux bussed to a master audio track with the green 'I' on) which disappear if I enable then disable Delay Compensation in the Options menu. The problems usually start when I put a track in record, or after new tracks are created. Not sure if it's UAD related though... This was happening in CS2 and continues in CS3...
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc.
Old 06-12-2009, 05:34 AM
Razorfish Razorfish is offline
Yikes... and I was about to do the CS upgrade!
Old 06-12-2009, 05:39 AM
And furthermore, I just had looping audio and crash when editing in Melodyne.
Old 06-12-2009, 12:39 PM
crizdee's Avatar
Its not a show stopper! but its something i have never seen before cs3.
Also today i have had to toggle delay comp on/off before it actually turned it off and gave zero latency monitoring.
Producer, Engineer,
www.ukmastering.com
Old 06-12-2009, 04:53 PM
DCommand DCommand is offline
Same here, melodyne and duende crashing and looping, PTHD8 have been nothing else but trouble
Old 06-12-2009, 07:50 PM
studiojimi's Avatar
studiojimi studiojimi is offline
the elephant is trumpeting all throughout the jungle is seems.
i downloaded the cs3 in my test drive.
i like how the logo says you are on cs3 when you launch now
it seemed ok....my eyes couldn't take but about 5 minutes of the GUI
i'll think i'll continue to stay in tiger and 7.4 with my clients
and play with my elephant when no one is around
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 06-13-2009, 12:10 AM
Yeah, its sad, i´ve been on protools since the early beginning and if digidesign cant make it work we need to consider another solution, i love a working protools solution dont misunderstand me here, but protools is not there yet
Old 06-13-2009, 12:40 AM
crizdee's Avatar
Sorry but i don't see how this is connected to delay comp issue that i'm posting about
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-16-2009, 09:12 AM
aidyhall aidyhall is offline
Hi crizdee,
I've not had a delay comp problem with wrapped plugs, but when I installed cs3, it didn't recognise any of my wrapped plug-ins, so I had to re-wrap the whole lot. Only took 5 minutes, and they work fine, delay comp and all ...
Perhaps that might solve your problem ...
Manual Delay Comp Problem WinTaper Pro Tools 9 74 09-28-2020 10:01 AM
PT 10.0.0 HD Native Automation Problem with Delay Comp Chris Trent macOS 5 01-07-2012 03:04 AM
Problem with Delay Comp. and not enough DSP/Time slots... storm-01 Pro Tools TDM Systems (Mac) 0 08-16-2007 01:54 PM
RTAS Plugs and Expansion HD: Delay Comp Question. JSR Pro Tools TDM Systems (Mac) 1 01-22-2007 10:35 AM
Problem with Wrapped VST plugs Tedmod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-23-2004 11:23 AM
