Old 04-27-2009, 03:42 PM
MELOSAGE MELOSAGE is offline
Default Procontrol problems
My Digidesign procontrol main unit and fader pack blink out sometime and i have to turn the power off for it to come back up. sometimes it come back online and some it don't..
Old 05-19-2009, 11:08 AM
Curtis Inc Curtis Inc is offline
Default Re: Procontrol problems
When you say blink out, what do you mean specifically? My edit back has been acting up a lot recently. All of the LED buttons will light up randomly and continously blink on and off. From time to time when I would lose sync with ProTools, I would reset the ethernet controllers and cycle the power on the units. This would solve the problem.
Jon
Old 06-19-2009, 10:42 AM
David Cole David Cole is offline
I'm seeing other threads, talking about either swapping out the power supply, replacing the filter caps on it, or just resoldering the connections on it. Mine has intermittently started blinking LED's, random text characters on the displays, dim LED's and all fingers are pointing to the power supply. Would love to know if anyone has a "how to" with photos of cracking open the ProControl.
-DC
David Cole
Noise In The Attic
www.davidcolemusic.com
Old 06-20-2009, 10:16 PM
Tweakhead Tweakhead is offline
When these symptoms happened to me it was the Power Supply capacitors. I found an excellent tech here in Los Angeles called Greg Granieri, who fixed it for me. His email is [email protected]
I believe he used to work at Digidesign.
Since he fixed it several years ago I have had no problems with it at all.
Old 06-21-2009, 11:37 PM
elicious elicious is offline
hi, we've had the same problem a couplea times in the last seven years...
found an outfit in irvine, ca. that makes the same power supply;
i think about 26 bucks,
slap it in, good to go.
b.o.l
e
ihatetyping
Old 07-05-2009, 10:56 PM
granieri granieri is offline
Thank you, tweakhead, for your recommendations. I'm at your service for any of your electronic needs.
Old 09-03-2010, 10:08 AM
mcosme mcosme is offline
Thank you elicious,...do you have a name for the company in Irvine, Ca???
Old 09-04-2010, 04:21 AM
Amtek Electronic Co.
Tel: 1-949-460-9712
Fax: 1-949-460-9716
Attn: Kao F. Hsu
American Skynet Electronics
you'll need the specs for the pwr supply
as they normally deal in bulk...
b.o.l.
e
ihatetyping
Old 09-04-2010, 03:49 PM
Thank you
Old 09-11-2010, 02:33 PM
defcon defcon is offline
I concur with the above post's I had the same exact problem with my Fader Pak and it was the solder connections to the header pins. Took me all of 20 mins or so, the majority was taking the PC apart enough to remove the power supply PCB. I am not saying that your issue is exactly the bad solder joints but its well worth checking (look closely if you do not see a solid solder joint it is suspect to cause an issue when it warms up) Otherwise having a new Power supply is easy enough to replace. I would keep the old one and rebuild it if possible for a spare.
Good Luck!
Nate~
"I put my heart and my soul into my work, and have lost my mind in the process." ---Vincent Van Gogh
Major Problems With ProControl in LE _Nexo_ ProControl, Control|24, Command|8 4 12-11-2015 07:30 AM
procontrol on pt 5.1 problems, anyone? toolowd Digidesign Hardware & Software 1 02-14-2012 10:00 AM
ProControl Problems Beatstreet ProControl, Control|24, Command|8 1 07-16-2009 11:56 PM
some problems about procontrol Techdisc ProControl, Control|24, Command|8 2 06-12-2001 09:54 AM
ProControl Monitoring Problems ? Olivier Roure Pro Tools TDM Systems (Mac) 36 11-16-1999 09:47 AM
