Old 03-05-2009, 07:47 PM
audiobob's Avatar
audiobob audiobob is offline
Default Satellite Connection message over and over
Every time I launch PT8.
"Could not create network sockets for Satellite connections. The TCP/UDP communication port may possibly be in use. Would you like to try again?"
Same warning happens when I choose Peripherals. Have had some crashes when going into Peripherals. This just started happening after I installed cs2. Went back to cs1 but still happening. Not a tragedy but annoying. Not sure what I've done differently to suddenly start this.
Old 03-06-2009, 12:23 AM
joji joji is offline
Default Re: Satellite Connection message over and over
if you look at the last page in perences. The syncronization page. There ia groupo of Satalite choices checked off when PT 8.0 is installed. I turned these off and that message went away. Not sure if that definitely did it but it worked for the moment
Old 03-06-2009, 05:21 AM
audiobob's Avatar
Thanks, I already did that though. I click no and it doesn't come up again until I either go to Peripherals or quit PT and launch again. It's just annoying.
Old 03-07-2009, 01:30 AM
edemunari edemunari is offline
Mee too!!! But is a PT problem or a bad integration with MAC Firewall?
I did both, joji hints and telling firewall to make enable connection as default.
Nothing make the annoying message stop.
pleeeeeaaaase give us a soloution or a workaround.
All the best
Ciao
Eriberto
Old 05-29-2010, 09:18 AM
balters balters is offline
i'm getting this same error everytime as well...
Old 05-29-2010, 09:45 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Did you check the settings for Satellite? Go to PERIPHERALS and click on the SATELLITES tab on the far right. Make sure ALL of the Sytems listed show NONE in the pull down menus.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Satellite dropping connection ! TommyT Pro Tools TDM Systems (Mac) 11 01-18-2012 07:00 PM
ProTools 8 - Video Satellite Connection Error ? AAR Pro Tools TDM Systems (Mac) 11 06-05-2011 07:12 PM
ProTools and Avid Satellite connection problem tfa Pro Tools TDM Systems (Mac) 2 06-02-2010 12:47 PM
ProTools and Avid Satellite connection problem tfa Post - Surround - Video 6 06-02-2010 12:46 PM
Video Satellite LE - Enable Satellite Mode is greyed out? Erik Olsson Post - Surround - Video 6 01-11-2010 09:16 AM
