Old 11-11-2008, 02:49 PM
TimNielsen TimNielsen is offline
Default Magma PE6R4
Had a search on the Digi site, didn't find the answer, figure someone here could tell me,
Putting an HD3 into a Magma PE6R4.
The PCI Express interface card, does it need to go into a particular slot in the Mac Pro?
I know the Mac Pro has 1 PCI 2.0 16x slot, and 2 4x slots. Since the Magma card is 4x, it should work in any slot, right?
Old 11-11-2008, 03:13 PM
ZEUSS ZEUSS is offline
Default Re: Magma PE6R4
Here is how mine is setup.
Although my mac is the first special order 8 core, I have the Geforce 7300GT in slot one X16. The bridge card is in the 4th slot. I have the first profile selected which is X16 Lane graphics slot+one X8 Lane and Two X1 lanes. This shows both cards running at maximum speed. My core card is in the chassi farthest to the right, followed by the process cards.
It has worked flawless for me for a year.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 11-12-2008, 09:39 PM
boogiemotel boogiemotel is offline
how loud are the fans in the chassis ?
Old 11-13-2008, 01:13 AM
bad jitter bad jitter is offline
They are loud. Chassis should be in another room.
Old 11-13-2008, 10:11 AM
There have been several posts on replacing the fans, which appears to cost around $30 and take the noise down quite a bit. And you can also replace the power supply with a $100 one or so, to get rid of those noisy fans. I expect I might have to do both of these things as I expect to have to have the chassis very close to me for now.
Old 11-14-2008, 12:58 AM
N.E.R.D N.E.R.D is offline
Insanely loud. You pretty much have to replace the power supply to make it quiet. I did that as well as put in a quiet fan. It is now almost silent.
Protools 8. 8 Core Mac Pro...
Old 11-14-2008, 01:17 AM
Which power supply did you go with, and where did you get it? I'm realizing I'm likely going to have to do this...
Tim
Old 11-14-2008, 09:34 AM
Did you do this fix your self or have it done for you ?
Old 11-14-2008, 03:17 PM
feakerboo feakerboo is offline
actually I'd like to know what you got and where you got it as well. I'm looking to replace my G4 and got knows I don't need to replace it with another Jet engine.
thanks
Old 11-14-2008, 06:19 PM
Tim
I got from a place here in Australia. I got a JSP Bluefire2 600w, but I think you can get pretty much any standard ATX PSU as long as it more or less fits the specs. Here is what Magma said when I asked them about it:
"It is not recommended to use a different power supply unit.
But if you prefer to use a commercialized off the shelf standard ATX power supply it is OK as long as you are using the same specs.
What about the 2 20-pin connectors? You can use any of the two 20-pins. You can plug a standard ATX PSU with one 20-pin connector."
I also put a quiet fan in the front intake. I put a noise fan reducer in too to slow the speed of the fan. Like this:
http://www.pccasegear.com/index.php?...oducts_id=3603
I'm no techie, but I found the job pretty simple. Took about 20mins.
Cheers
Magma PE6R4-I or PE6R4 EM Iker Pro Tools TDM Systems (Mac) 16 10-07-2016 02:27 AM
PT8.1 with Magma PE6R4-I mattbell1978 Pro Tools TDM Systems (Win) 0 03-18-2014 07:19 AM
Wtb: Magma pe6r4 RCN Buy & Sell 1 06-02-2012 08:39 AM
Magma PE6R4 subwoof Post - Surround - Video 4 03-21-2010 02:18 PM
Anyone using the Magma PE6R4 with a G5? mixboy bob Pro Tools TDM Systems (Mac) 4 06-11-2009 08:29 AM
