Renaming exported audio files using copy & paste
When exporting audio files (Shift+apple+K)to an outside folder and then trying to rename the file name by copy/pasting a file name from a different audio file only works once. Thereafter, the clipbopard will not allow a new name to be copied. It keeps pasting the first name you copy.
This works fine in OS9 5.3.1 all day long, but will not work in PT 6.xx This is a huge pain for dialogue work, when a file name has to be renamed to match a script name. I have many situations where I have an English file and a Spanish file that have to have the same name. Obvioulsy you can't have the files names exactly the same in the same session...so, I have to export them one by one, and copy the file name from the playlist and then paste it to the exported file folder, per file. I thought it was an OSX thing, but I checked MS Word and others and the copy paste works fine. I have tried this on 3 TDM systems running PT 6 & 6.2.3 and no luck. Anyone else have this problem or know a fix??? Steve
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
Re: Renaming exported audio files using copy & paste
Anyone?
Exported Audio Files Different Lengths to Clips in Session | alex s | Pro Tools HDX & HD Native Systems (Mac) | 7 | 03-18-2013 04:18 PM |
Protools Le 8 exported audio files compatibility | mat13055 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-29-2010 01:08 AM |
How do I copy and paste audio files? | tioluis | Pro Tools TDM Systems (Mac) | 4 | 07-01-2007 10:22 AM |
When I copy audio and paste it somewhere else..... | AbjectEvolution | Pro Tools M-Powered (Win) | 5 | 09-04-2006 11:52 AM |
Renaming exported audio files using cut & paste | soundboy35 | Pro Tools TDM Systems (Mac) | 1 | 09-07-2004 05:13 PM |
