Old 05-13-2017, 10:41 AM
Goombot Goombot is offline
Default PT 12.7.1 and 12.7 bouncing and opening issues
I created a case for this but we all know how long that takes. I'm on a Mac Pro 6 core, 32 gigs of RAM, 10.11.7? and PT 12.7.1 and/or 12.7 with PTX mixing television. My template has not changed in months, my plug-in's have not changed and they are fully updated. I've had two issues and I'm wondering if they're drive related. This is the error I get..
"Unable to bounce offline. Error while preparing: "Assertion in "/Volumes/Development/200028/ProTools/NewFileLibs/SMgr/SMgr_StConnectionPrep.cpp", line 73." ... Do you want to do a real time bounce instead?
So sometimes I'm able to open, work and bounce but only once. Never twice without closing the session and re-opening. Some other times I work and then try to bounce and get this error...
"Could not complete the bounce to disk command because vector"
Sometimes I work, then close, then I cannot open.
I think I've tried most things. I cleared all unused clips and tracks. No luck. I copied the session to a different drive, same issues (which makes me think it's not a drive issue). I did a save session copy, same issue. I moved from PT12.7.1 to PT12.7, same issue.
The only thing that worked was creating a new session with the exact same template, re-import everything and then I'm able to work and bounce, but again, only ONCE.
I am mixing televison so I have an AAF created from Media Composer v 6.6 and always a high rez ProRes video in the session.
Old 05-14-2017, 06:23 AM
john1192 john1192 is offline
Default Re: PT 12.7.1 and 12.7 bouncing and opening issues
can it be tracked to One Plugin giving you grief ???
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-22-2018, 02:50 PM
Interactivesound Interactivesound is offline
I'm having this problem again with a session. I had it once before and traced the problem back to a file with an invalid character in the name. When I renamed and re-imported that audio file, I was able to bounce again.
This time, I have a different cause. No file name issues. I'm using a template that I have used to mix this TV series for 2 years, and suddenly today I cannot output the current episode. I'll let you know if I figure anything out.
What I do know Is I can bounce my masters individually by left clicking and choosing BOUNCE from the context menu. That has been my workaround to finish the project. Bouncing each stem offline individually.
Bouncing Issues McLuckie Pro Tools 9 7 04-12-2013 06:51 PM
Bouncing issues pjmusiced Windows 0 05-04-2012 12:13 AM
How do I keep iTunes from opening after bouncing a QT? rhumphries Post - Surround - Video 13 03-12-2012 01:45 PM
Bouncing Issues benplaysmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2011 10:00 AM
Bouncing Issues...SERIOUSLY?!?!?! mforehand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-10-2007 12:59 PM
