Old 01-16-2017, 02:44 PM
Benoni's Avatar
Benoni Benoni is offline
Default Plug & Mix Basspeg Crashing PT12.7 On Startup
Plug & Mix updated the VIP pack, which I have installed. Upon launching PT 12.7, it crashed and hung on the new Basspeg plugin. Attempted several more launches, always crashing in the same spot.
I moved Basspeg to the Unused folder and now PT launches just fine.
Anyone else seeing this? I'm on Windows 10, PT 12.7
http://www.plugandmix.com/news/n40-P...he-VIP-Bundle/
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-16-2017, 04:09 PM
amagras amagras is offline
Default Re: Plug & Mix Basspeg Crashing PT12.7 On Startup
Did you try with PM Chainer?
amagrasmusic.com
Old 01-16-2017, 04:28 PM
Benoni's Avatar
Well, it crashes on startup of Pro Tools, so I can't even get to Chainer. But I will install the latest version of chainer and see.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-16-2017, 05:03 PM
DHL DHL is offline
Same here. I was excited to try it out last night, but I had to uninstall it right away.
Daniel
Asus P6X58D-E, Intel i7 930, 12 Gb Corsair XMS3 DDR3
2 WD Black Cavier 640 Gb SATA 3Gb/s 32MB Cache
Windows 10 Pro
Old 01-16-2017, 06:33 PM
I only ask because Chainer loads all their plugins even if you don't have them in AAX. Maybe it is possible to use it that way until they come up with a fix.
amagrasmusic.com
Old 01-16-2017, 07:18 PM
Benoni's Avatar
Yeah, i'll give it a go and see if I can use it that way.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-16-2017, 07:19 PM
Benoni's Avatar
Confirmed then, good, it not just something with my system.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-17-2017, 03:00 AM
Stephen Bond's Avatar
There's some issues with BassPeg it seems? Probably worth reporting your woes here.
http://forums.plugivery.com/index.ph...=315&start=315
That said I have been using it OK!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 01-17-2017, 05:39 AM
clausiii's Avatar
clausiii clausiii is offline
i have the problem that the message comes up: "Clarisonix and Distorted are not valid 64 bit AAX plugins."
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 01-17-2017, 12:15 PM
Carl Kolchak Carl Kolchak is offline
That's a bugger!
I was looking forward to updating, and giving Basspeg a whirl.
I'd definitely raise this issue on the previously linked bug report thread, on their forum.
I've found them to be responsive, and pretty swift at fixing bugs that have effected me.
That said, I detailed several significant bugs (on page 21 of the bugs thread), and there have been no updates until now.
I hadn't laboured the issue, as there were various things going on at Don't Crack that were obviously going to put VIP updates on the back burner, and I just worked around most of the problems until I forgot about them.
Would be interested to know if this new release (new bugs not withstanding) has addressed any of those previous issues I raised.
HTML code is On
PT First Crashing on Startup SIU Telehealth Pro Tools | Intro Discussion 3 12-19-2016 08:25 AM
Pt12.6.1 crashing marcsprotools Pro Tools 12 7 12-12-2016 04:59 PM
PT12 crashes during startup when loading plugins MikeV252 Windows 2 12-06-2015 07:01 PM
pt 8 le mixer plug ins crashing program at startup pounceinternational 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 12-31-2008 06:46 AM
PT LE Crashing on Startup beggehorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-18-2006 09:18 AM
