Old 02-08-2009, 05:04 PM
mjames08 mjames08 is offline
Default Upgrade to PT8 = Low levels?
Hello all,
I recently upgraded to Protools 8 HD from Protools 6.9 HD, and now I'm getting a lot lower of a level coming into Protools via 192io. I made sure I was using the same input trims I was using before, but now I've got my preamp turned all the way up and still getting a lot less signal than usual. Has anyone else experienced this? Could there be a setting that I am missing somewhere?
Any help is appreciated!
Old 02-09-2009, 02:17 AM
kinghand kinghand is offline
Default Re: Upgrade to PT8 = Low levels?
I upgraded from PT 7.4 and everything's fine.
Old 02-09-2009, 02:34 AM
NickH NickH is offline
Originally Posted by mjames08 View Post
Hello all,
Try Setup:Hardware:
And check that your input levels are set to +4 on your 192
Cheers
N
“It’s because you touch yourself at night... ”
System Specs
Old 02-09-2009, 06:45 AM
Originally Posted by NickH View Post
Try Setup:Hardware:
Cheers
N
Input levels are at +4. I'd rather not downgrade back to 6.9, but I am getting unusable signals coming in from equipment that worked great before.
Old 02-09-2009, 11:07 AM
DigiTechSupt's Avatar
What brand/model of preamp is this and how do you have it connected?
Avid Audio Tech Support
Support FAQ
Old 02-10-2009, 06:43 AM
It's a universal audio 2108. It's connected directly to the 192 via db25 XLR cable. I had a guitar cab blaring, mic'd with a 57 getting the pre into the red and the output cranked doesn't bring protools into the orange. The sansamp rack connected the same way used to drive protools into the red, now with it all the way up I am getting very low signal into pt.
Could this be a coincedence and my db25 cable went bad? The digi link cable also? I have two 882s also, are they handled differently in pt8? I'm getting great signal from the Adat in from my digimax...
Old 02-11-2009, 12:27 PM
It ended up being the db25 cable... thanks for the replies!
Tracking Levels and Playback Levels paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-26-2010 05:37 PM
Creating the best mix levels / playback levels universe777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2006 10:49 PM
Broadcast levels vs. Podcast levels... McBoob Post - Surround - Video 0 05-05-2006 08:03 AM
Linking track levels w/ pre-fader bus levels? Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2003 10:36 PM
Mix levels vs. monitor levels badshirt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-05-2001 12:17 AM
