Disappearing Elastic Properties
Hi all!
Been having this issue since installing 2019.5, *most* of the time every elastic property is grayed out/unchangeable other than pitch shift. TCE etc did randomly come back once, but has since disappeared again. I've attached a screen grab to illustrate... I've tried re-installing, opening/creating other projects but it still doesn't work. Anyone else having this issue, or am I inadvertently toggling some setting I'm unaware of? Thanks! |
Re: Disappearing Elastic Properties
Seems like it might be something with the video card or driver. Have you tried trashing preferences?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Thanks, unfortunately trashing the preferences did not solve the issue
Are you still on Windows 7? Not sure if that would have any bearing on the issue.
I'm on Windows 10, fully updated
*edit to add* s a video card issue, I'm using a GTX 970, also updated |
Ah, your profile says Windows 7.
Oh thanks, changed!
I've just got the same thing on a mac.
On occasion I will have access to the properties when I first open a project, but the they disappear again within a minute or so...
Elastic audio is a mess! I use it a lot and it's now totally unusable.
recent issues that popped up in 2019.5 (after weeks of no problems) are... when I switch from real-time algorithms to x-form, Pro Tools renders the files but no audio plays. If I enable formant correction, it changes the timeline / audio and it's all not what I had. Only some analysis markers turn to warp markers when quantizing!!! This is stuff I use everyday. and this is $400/year!??? I'm baffled at how Avid keeps screwing up EA with every release!!! |
Elastic Properties - Warbled Sound... | YoBroMan | Pro Tools 10 | 3 | 09-15-2012 06:15 PM |
Elastic Properties - from PT8 to PT7.4 pitching | Farmer Dave | Pro Tools TDM Systems (Mac) | 1 | 01-31-2010 12:16 AM |
Where's my Elastic Properties? | Reesho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-13-2010 06:32 AM |
Elastic Properties | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2009 05:20 PM |
No Elastic properties in 7.4 | xxicjoy | Pro Tools TDM Systems (Mac) | 2 | 02-27-2009 01:44 PM |
