MobilePre 1.1.8 driver
Hi there!
I've got some issues with the Avid drivers (1.1.7 and 1.1.8). My problem is that when I play guitar with my Amplitube 3.12 standalone amp simulator and play along an other program (Guitar Pro 5 or Youtube for exemple), I get a crackling sound that is really anoying. Even if I change the buffer size, the problem is the same. I can play without any problem with amplitube 3 only, or guitar pro only. It just starts crackling if both are openned. (I don't have any issues with the 1.0.4 driver, but it isn't good for when I record in Pro tools :/ ) If someone has an idea of what could be the problem, it would be nice! Thanks in advance! |
Re: MobilePre 1.1.8 driver
I would submit a bug report if I were you. Also check the Help us Help You - READ THIS Before Posting! link on top of the forum and follow every step in there including posting a Sandra report here. Also check what settings are the playback settings for windows (I'm assuming you're using a windows machine here since you posted in the windows section but without computer information it's only an assumption) Go to start -> control pannel -> sound -> playback -> select your audio interface -> properties -> advance -> and make sure that the settings there matches your interface settings and your software settings.
MobilePre 2nd Gen on Win7 | prints | General Discussion | 3 | 01-13-2013 08:18 PM |
Mobilepre USB? | velvetlounger | General Discussion | 5 | 12-13-2012 06:45 PM |
Mobilepre Driver | c0m3t0g3th3r | Pro Tools M-Powered (Mac) | 3 | 04-20-2010 02:52 PM |
Problem with MobilePre | Midside21 | Pro Tools M-Powered (Mac) | 5 | 02-11-2008 07:29 PM |
MobilePre USB Driver-PTF Does Not Recognize | wdannevi | Digidesign Hardware & Software | 1 | 06-21-2003 09:30 AM |
