Old 12-01-1999, 10:18 AM
Greg Malcangi Greg Malcangi is offline
Default Fast Forward/ Rewind
Sometimes, holding down the fast forward or rewind buttons only fast forwards or rewinds at half speed. However, holding down these buttons with the mouse in the transport window fast forwards or rewinds at the normal speed. Quiting the session and going back in sometimes cures the problem, whereas rebooting always does. I've had this problem with 4.2 and it hasn't gone away with PT 5.0.
While I'm at it, in PT5 is there a way to return to the previous start point when stopping playback? Using markers is a bit time consuming and can get messy when all I want to do is play it again from the same place.
Minor gripes these, I'm generally very pleased with both PT5 and my new PC.
TIA,
Greg
Old 12-01-1999, 04:06 PM
George Cumbee George Cumbee is offline
Default Re: Fast Forward/ Rewind
I haven't seen the PT5 Preferences yet, but in 4.x go to Preferences and then Operation, top box checks where to play from insertion point or not. Unchecking that box will jump back to last insert point each time you hit play. The other way will play from where you stop. Both have their needs depending on what you are doing. I hope this is still there in 5.O
George
Classic Recording, Franklin, TN
www.classicrecording.com
George Cumbee, Pres.
Audio Creations Inc., Paducah, KY
Classic Recording, Franklin(Nashville), TN
Old 12-02-1999, 06:41 AM
Thanks George. I'm new to PT, when I installed 5 the selection in preferences was different to the default setting when I installed 4.3. Following your instructions it does exactly as I wanted.
Any suggestions on the FForward/Rewind on the PC problem?
Cheers,
Greg
[This message has been edited by Greg Malcangi (edited 12-02-99).]
Old 12-02-1999, 07:59 PM
I never use the transport buttons, so I was not aware of that. I will check it out next time I am at the studio. I own the studio in Franklin (Nashville), TN, but live in Ky. I go down to my projects and it operates without me (3 staff people/free-lance eng.) when I am home.
I will let you know if our does the same...
George
Classic Recording
ProTools HD locked up w/fast forward and rewind lit up mingalls macOS 6 10-02-2023 10:33 AM
Fast forward & rewind speed - D Command & D Control wint Pro Tools 9 3 06-29-2011 07:48 AM
Cursor jumps too far with Fast Forward/Rewind bender-offender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-30-2010 08:11 AM
chase LTC during fast forward rewind drudwn Post - Surround - Video 3 09-05-2006 08:44 PM
Forward/Rewind on Macbook rabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-23-2006 08:52 AM
