Old 10-06-2015, 02:34 PM
Oroz Oroz is offline
Default PT 12 Meters Not Showing Red (clips)
Hi everyone, I'm having trouble with PT's meters. They're not showing red or clips anymore and it's very deceiving. I don't know what's going on, how can anyone mix this way?
I've tried changing to all type of meters and they all behave the same way (even the PT Classic). Even if I put the Master fader all the way up. Distortion is obvious, you can hear it but I can't see it.
What's up with that?
Thanks in advance!
Old 10-06-2015, 02:42 PM
GeoffLee GeoffLee is offline
Default Re: PT 12 Meters Not Showing Red (clips)
I think it works for most people! I've got nothing useful to add except to say that you should have clip warning on steroids - the name of the track in the tracks list also turns red when the track meter shows a clip.
Protools Studio 24.3, 2018 Mac Mini, Core I5 6 core, 16Gb ram, Sonoma 14.4, Focusrite Clarett+ 8pre, Focusrite Octopre.
Old 10-06-2015, 03:39 PM
Two different set ups at different studios behave like this. I thought that it was something that PT 12 implemented with it's new meters or something like that.
Old 10-06-2015, 03:42 PM
mesaone mesaone is offline
You should have yellow clip lights on all tracks but the master.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 10-06-2015, 04:29 PM
Siegfried Meier Siegfried Meier is offline
I've seen this happen as well. It seems in the Edit window the meters won't show a red/clip, but they do in the Mix window.
I just assumed this was a bug, like the 10 million other things that have been present with 12HD...
Old 10-06-2015, 04:30 PM
Z-Chord's Avatar
Z-Chord Z-Chord is offline
Are you running the session at 32 bit float? I'm not for certain on this one, but I think that increases your headroom inside of the DAW a staggering amount. If so, the distortion from clipping that you're hearing is in your converters themselves and not in Pro Tools, which may be your issue. Again though, I'm just guessing. Anyone have anything to add to this postulation?
Pro Tools 2020.5
2018 i7 Mac Mini 32 GB RAM
"Great things are done by a series of small things brought together." -Vincent Van Gogh
Old 10-06-2015, 04:37 PM
PT internal mixer operates with floating point math regardless of session settings. Internal audio can exceed 0 dBFS without adverse effects as long as it is attenuated down below 0 dBFS before it gets sent out to a file or to a converter. Once you hit that master fader, you can actually clip.
Old 10-06-2015, 05:03 PM
Clip lights up in both my Edit and Mix windows. The track name also turns red in the Tracks list (edit and mix windows).
Old 10-06-2015, 05:18 PM
Z-Chord's Avatar
Thank you for clearing that up for me. Best of luck to the OP!
Pro Tools 2020.5
Old 10-06-2015, 05:30 PM
No, I'm running the session at 24 bits.
Best regards.
showing parent clip group of offline-clips Frank Kruse Post - Surround - Video 2 04-14-2015 08:53 AM
edit window not showing clip on a meters dmitri85 Pro Tools 11 9 10-25-2014 03:03 PM
Meters showing inaudible sound when record enabling input 1 on the mbox 2 mini jt1432 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-15-2013 06:37 PM
no audio or meters showing on playback P,B,S Pro Tools 11 0 06-25-2013 05:45 AM
XMON central meter section not showing meters tonmeistermat ICON & C|24 2 11-15-2006 04:38 AM
