noises from TC MegaReverb on big sesson
I'm getting pops and clicks on the output of TC MegaReverb, usually only on the right side. My session is nearly maxing out my system, with tons of tracks and plug-ins. I have the TC plug in inserted on 2 stereo aux returns, with a different setting on each channel. The pops occur on both aux channels, but nearly disappear if one of the TC inserts is removed. Also, Digitest 5.0 didn't detect my Mix card (3.3 did, and it passed) Downloaded MegaReverb 3.0, but didn't fix it. <G3/300beige dt,192 meg,Mix,5.0,888/24,USD>
Re: noises from TC MegaReverb on big sesson
When I have DSP problems I first try re-inserting the plug-in. Once in a while that actually works. If not, I re-load the session. If that doesn't work re-boot the computer and be sure to re-set the expansion chassis as well. Most of the time that does it. Also try the usual, like trashing Digi Set-up. Hope I'm not stating the obvious.
Good Luck.
Barry Young Young Creative |
I 've had these same problems with my
G3/300 beige....but I don't think it's the machine. I too have the latest version of Megaverb 3.0 I think it's DSP power ..I only have a Mix System and can't use Megaverb and any other plug-in without thes pops/sizzles... hope this helps PT 5.0...60mb DAE 5.0...65mb 384 total mb grey post supervisor www.soundwerx.com www.iNioz.com |
Well, I'm still having the problem, even with MegaReverb vers. 3.01. I can work around it by recording the 'verb, and punching in over the pops, but it's not a good way to work. I'd like to find the cause. Any more ideas anyone? Thanks.
I've had what you describe (Megaverb) once when I was close to maxxing out, but I just did what Barry did and it went away - no recurrences, but I haven't been that deep for a bit.....
"it's not about making the changes, it's about playing ideas in time" Scofield... |
Help! Lost Sesson | srvenable | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-30-2010 06:58 AM |
Swapping Sesson info between sessions | Ironbear9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-26-2008 09:05 AM |
Will TC Megareverb be HD compatible? | littledog | Pro Tools TDM Systems (Mac) | 1 | 05-14-2002 10:51 PM |
TC MegaReverb crashing 5.0.1 | gtwrwy | Pro Tools TDM Systems (Mac) | 1 | 06-28-2000 05:19 AM |
Waves and MegaReverb | Dog BBQ | Pro Tools TDM Systems (Mac) | 7 | 12-28-1999 07:44 AM |
