Reverb Plug-In with BPM controlled predelay/tail
Hi Folks!
Before I got my DSHOW Profile, I used the Eventide Eclipse hardware product for reverbs. With the eclipse I could control pre-delay and tail of my reverbs with a BPM pedal, which I also used to control my delays. It was very sweet. I only needed about 4 different combinations of drum and vocal reverbs and let the tempo controls do the rest. I make good use of the BPM function in my profile and am using it to contol delays & chorus/flange effects. However, I haven't found any VENUE Plug-Ins that will allow me to do the same with reverb. Does anybody know of an available reverb plug-in that will do what I want? Or is there some method by which I can use a scene or something which will activate different reverb patch settings based on tempo? Please advise!
--garret 8-) Garret Hansen T 605.351.3282 F 610.661.7368 E [email protected] E [email protected] |
Re: Reverb Plug-In with BPM controlled predelay/tail
Whooo hooo, a six year old thread with no answer in...
At least I don't have to writ the question, because it is exactly the same, Is there a reverb plugin that reacts to the bpm of the console? |
I'm sure you can find a chart with the conversion from ms to bpm on Google. Not exactly a pedal but it works.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com Last edited by amagras; 05-25-2016 at 04:51 PM. Reason: Typo |
It would be easy enough to bus feed a reverb with 0ms predelay, and then insert a delay plugin (0 feedback/repeats) on the return that's linked to tempo, or vice versa. doesn't do much for catching tail though
That workaround sound ok, but not with the limited DSP resources of the S3L
Extending a reverb tail? | eidschun | Post - Surround - Video | 10 | 09-15-2008 08:11 AM |
Extending a reverb tail? | eidschun | Pro Tools TDM Systems (Mac) | 7 | 09-12-2008 05:15 PM |
Best way to create a reverb tail | Arch Stanton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-29-2007 07:59 PM |
Adjust Reverb Predelay / Tempo of a song | Aquarius | Tips & Tricks | 3 | 07-13-2006 01:39 AM |
Sony Oxford Reverb predelay | szajac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-16-2005 06:03 AM |
