Acoustic panel fittings
I've made myself 9 acoustic panels to hand in the corners, walls and ceiling. What I'm not to sure on is how to fit them to the walls. I know for best results they should have a 4 inch gap between the wall and the panel. Any one here help with suggestions
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Acoustic panel fittings
shooting from the hip; mount 4" blocks at each corner(wrap or paint the same as the panels). Drill an angled hole in the top 2 corners and hang with long finish nails Having said that, all my panels are hung on the wall. Before I wrapped the fabric, I used a Kreg Pocket Screw gadget to drill angled holes(2 top and 2 bottom). Once the fabric was wrapped, I slit where the pockets were cut and mounted to the wall with long-ish pocket screws(the square-drive heads work really well without the driver slipping)
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
$70 for a package of 8 seems pricey to me. I would rig something up with wood blocks as Albee suggested if you are going to be hanging 9 panels.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
French cleats made of plywood, as shown, or wood, or Z-Clips.
To keep the panels the same distance from the wall at the bottom as at the top, put a piece of Styrofoam at the bottom the same width as the gap at the top.
Any U shape Bracket can work as long as it gives you the right spacing. You could even buy some sheet metal pieces and bend them yourself with a vice and deilll mounting holes where you need them. The obvious issue with using blocks or other similar type mounting strategies, is that to connect the blocks to the panels, requires you to have to drill through, or rather screw through, the front of the panel, potentially causing cosmetic issues. I have to go to one of those two stores I mentioned above this weekend, I'll look around for some ideas there, for a cost-effective way to mount that doesn't potentially cause any issues with needing to screw anything through the front of the panel.
On a sidenote, the Kreg unit is a must-have for any hobbyist. The unit and it's various adapters are pricey, but worth every penny!
I agree that the panels are more effective if spaced off the wall, but my room is a bit tight for panels that stick out 7+ inches(they are already 3-3.5" thick). On my CR back wall(where this would likely be the most important, in my CR, the back wall actually is plywood, at angles, with holes thru and several more inches of rigid fiberglass, so the wall was already off to a decent start I bet the french cleat, cut from a 2x4 would work well, and give a decent space behind
French cleats are cool, never seen them
device panel | thiss | Pro Tools SE and Essential (Win) | 9 | 09-19-2011 11:36 AM |
ProTools 9 I/O panel fix?!? | VRS | Pro Tools TDM Systems (Mac) | 3 | 03-03-2011 09:04 PM |
How can I take off the side panel of C24? | seeit | ICON & C|24 | 0 | 11-05-2009 07:09 AM |
Back panel of 96 I/O | Alécio Costa | Pro Tools TDM Systems (Mac) | 20 | 04-02-2002 10:43 AM |
No Transport panel | Extreme Mixing | Pro Tools TDM Systems (Mac) | 2 | 02-25-2002 01:38 PM |
