Old 05-31-2017, 07:32 PM
dubpmogly dubpmogly is offline
Default Probably a very noob question... Assertion line 1624
i used to have pro tools nine with a little fast track box.....stopped working when i upgraded to yosemite.....trying pt first for the first time and after installation gives me this msg when trying to open a session
Could not create a new document because Assertion in "/Volumes/Development/158351/ProTools/DFW/Views/UMenu.MacOS.mm", line 1624.
also prompted something about playback engine 44.1 khz or something.....
any help would be greatly appreciated and apologies ahead of time if this is a stupid question....
os 10.6
Old 06-01-2017, 03:52 AM
Default Re: Probably a very noob question.....
There's no such thing as a stupid question. Having system info would help - you give us none other than running some version of Yosemite. To save time a lot of people put their system specs in their profile with a note in their sig file to that effect.
Try holding down the 'n' key on your computer as PT starts up. You should be able to select your audio interface (whatever that is).
Jack
QAPLA!
Old 06-01-2017, 04:51 AM
thanx for the response.....sadly holding "n" had no effect....also im currently running on a mac os10 10.9.5....dont really know what my audio interface is...not at all tech savy.....i use a little m audio box to plug in my mic....all it says is maudio fast track.....bought a little pro tools se package back in the day......then upgraded a little later to pro tools nine.....but yeah all that stopped working after i upgraded my mac......so i actually re installed or re started or wiped my computer clean to get back to the old os....but couldnt find the og installation disks for my pro tools....now i was just trying to give pro tools first a try to no avail.....again only gives this msg....was just wondering if my "fast track " is just completely incompatible or am i missing something simple
os 10.6
Old 06-01-2017, 05:07 AM
That MBox IS your audio interface.
Not being tech savvy is making you your own worst enemy. You really need to either get smart and learn about Macs and computers in general or get someone to help you. We need to know EVERYTHING about your system to even begin to help.
Jack
QAPLA!
Old 06-29-2017, 03:45 PM
DannyB_KY's Avatar
DannyB_KY DannyB_KY is offline
As a mac user, I highly recommend you upgrade your OS to Sierra.
Click on the Apple in the upper left corner. Click on "About this Mac" and that will tell you about your Mac. What processor, what OS version, how much RAM you have, ect.
An understand spouse, some mics, tube guitar amps, gray foam stuff stuck to the walls, a drum kit, a Mac or two, and an interface. A really understanding spouse!
Old 06-30-2017, 06:10 AM
That won't necessarily help cure the problem. What is happening isn't an OSX problem itself and the poster not being tech savvy isn't helping things.
BTW - got a bottle of Mr. Beam's finest out in the kitchen - nice stuff.
Jack
QAPLA!
Old 07-13-2017, 11:00 AM
platonicbomb platonicbomb is offline
I'll tell you what this pertains to, as I am having the same problem. Here is a series of screenshots that show what I see when I open Pro-Tools First:
Macbook air 2012
Mac OS Sierra 10.12.4
8GB RAM i5 CPU
Pro Tools First
Scarlett Solo
Audio Technica AT2035
Home recording. Specs:
Macbook Air 2012 8GB RAM i5 CPU
Scarlett Solo
Old 07-13-2017, 11:01 AM
and a few more screenshots:
File Type: jpg Screen Shot 2017-07-13 at 1.55.45 PM.jpg (44.1 KB, 0 views)
File Type: png Screen Shot 2017-07-13 at 1.56.42 PM.png (91.0 KB, 0 views)
Scarlett Solo
Old 07-13-2017, 11:51 AM
And the way I solve the problem is to plug my Scarlett Solo into the USB on the LEFT side of my computer instead of on the RIGHT side. And the problem goes away. Which is about the lamest thing in the world, for Avid to send me on such an effing goose-chase instead of saying "we're not compatible with your right USB port, switch to the left please".
But so it goes. Here are fresh screenshots. Note that system in/out is my Boom device, and hardware engine is Scarlett Solo.
Scarlett Solo
Old 08-02-2017, 04:27 AM
huzzam huzzam is offline
Just to be sure: have you installed the drivers for your FastTrack? Try searching google for "m-audio fasttrack drivers mac" and follow the instructions. if you don't have your drivers installed, Pro Tools won't be able to find the audio interface (the Fast Track).
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Assertion in line 304 lobenmai Windows 0 12-24-2013 08:55 PM
Assertion line 330 steveskinner macOS 9 12-22-2012 10:34 PM
Assertion in ... line 199 Simmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-23-2012 02:53 PM
Assertion line 74 mikeeovitch macOS 0 10-08-2011 05:53 PM
Assertion line 481 jrtme Pro Tools TDM Systems (Mac) 2 04-18-2010 10:19 AM
