EuControl v3.6 Now Available
Avid is pleased to announce the release of EuControl/Workstation software version 3.6 for the S3, Dock, Pro Tools|Control, and Artist Series. Log in to your Avid Account (for S3, Dock, and Pro Tools | Control) or My Artist portal to download the new software.
Mac Release Notes EuControl 3.6.0 for Mac OS X ● Improved Knob Response ● Multiple EUCON Commands in Soft Keys ● Improved Pan Knob Mapping (2 knob panning) – Requires Pro Tools 12.7.1 or higher ● New Soft Key Commands ● S3 OLED Dim control ● Fixed Pro Tools | Dock Alt key issue ● Fixed High CPU usage ● Fixed Break on Color issue in iPad Control App ● Fixed being able to have more than 1 DAW Mackie control (MIDI ports) ● Fixed EuControl Crashes Win Release Notes EuControl 3.6.0 for Windows (64-bit) ● Improved Knob Response ● Multiple EUCON Commands in Soft Keys ● Improved Pan Knob Mapping (2 knob panning) – Requires Pro Tools 12.7.1 or higher ● New Soft Key Commands ● S3 OLED Dim control ● Fixed Pro Tools | Dock Alt key issue ● Fixed Break on Color issue in iPad Control App ● Fixed EuControl Crashes Readme Please note the following: Make sure control surface firmware is up to date after installing EuControl 3.6 A new version of Pro Tools | Control (v3.6) is available on the Apple App Store |
Re: EuControl v3.6 Now Available
Since installing 3.6 my Digi/AVID JLCooper Joystick stopped working.
I have a little midi monitor program running confirming that the controller data is getting to the system but PT doesn't recognise it anymore. It does work sometimes after a fresh reboot of everything but will stop after a while. Can this be EC3.6-related? Does anyone have this combo who can check? Thanks! Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Did you check the prefs in PT are still set correctly ?
Yes, took it out and put the Joystick back in under peripherals several times.
Midi is positively flowing to the OS. MidiMonitor confirms when I move the stick. Also Spancontrol on iPad for Spanner seems to randomly crash since I installed EC3.6 All worked fine under the previous version. Didn't change anything else. Thanks Frank.
The easy check is to uncheck EUCON in peripherals and see if it comes back. Also quit EuControl.
Tried that, doesn't help.
Strange thing is LEDs on the Joystick reflect the pan window opening/closing in PT but the rotaries and stick are not recognised neither or button presses. So the joystick gets info from PT. I think the incoming midi to the joystick works but the midi going to PT isn't recognised my PT. The OS however sees both. Strange...
After trashing all prefs incl. Midi, I got the Joystick back to work. Now all rotaries and buttons and the stick work but none of the control LEDs. So everything is the other way around than before. But I can live with that.
Frank.
Hi! Would you help me to find out when the IPad Pro 12.9 will be supported?
Thanx |
The 12" ipad does work in landscape mode but not portrait, which is what is needed for it to fit into the Dock's mount. I don't have a date for it to work in portrait mode unfortunately as its a complete rewrite.
With regards to the 2 knob pan setting, got it working here which is great, however it seems as the setting is not saved with the session, i.e. I have to turn it on every time I open a session? Is that the expected behaviour?
Thx, JR
J.R. Fountain credits: www.imdb.com/name/nm0288354/ system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12 |
EuControl 3.4 | mbryan67 | Avid S1, S3, Dock and Control App | 5 | 05-27-2016 02:23 PM |
EuControl 3.3.1 | Cryos | Artist Series | 10 | 01-13-2016 01:58 AM |
About EuControl 3.2 | Marcel Risberg | Artist Series | 10 | 06-26-2014 04:18 PM |
Eucontrol | wgouldsby | General Discussion | 3 | 02-25-2013 01:36 PM |
Eucontrol 2.6.2 out | robertg | Artist Series | 22 | 11-07-2011 12:11 PM |
