Old 10-12-2016, 02:51 PM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
Default Problem with Pro Tools Control & Eucon
I have installed Eucon 3.4.1 11610116 which is what is in my Avid Master Account and I have the Control app v1.0.7 11610116 on my iPad running iOS 9.3.5 and although the Eucon app on my Pro Tools computer, running 10.10.5 with PT 12.6HD shows my Pro Tools Control app as available when I select Add I get an error message saying that Pro Tools Control can not be added because it is not compatible with the installed version of EuControl.
I have updated the OS on my iPad, I have deleted and re-installed the app on my iPad. I have had it working before I updated to the latest version of Eucon. Any ideas please?
Thanks, Mike
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 10-13-2016, 08:25 AM
Default Re: Problem with Pro Tools Control & Eucon
When I came to boot up this morning it all worked fine so it probably was just needing a full reboot. All is well.
Mike Thornton MIPS
Old 11-01-2016, 10:55 PM
edwinh edwinh is offline
I have this problem consistently regardless of how many times I reboot. I'd love to get it figured out.
Macbook Pro M1 Pro
PT 2022.6
MH ULN-8 x3
Old 11-06-2016, 04:56 AM
john1192 john1192 is offline
make sure you iPad App is up to date .. reinstalling as Mike did, i have not seen this yet ....
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 05-16-2017, 01:57 PM
joren joren is offline
For others:
I have had a similar issue:
Correct versions of both eucon and app, but still getting the incompatibility error.
I solved it by setting a different name for my ipad (general ios settings).
It had an apostrophe in it and that showed up weird in the eucon software.
Making it shorter may also have helped
Mac Pro 8 core OSX Mojave
PT10HD, PT11HD, PT12HD Native
3x Avid Artist Mix, Euphonix MC Transport, PT|Control
Eucon and Pro Tools Control not working chrismeraz Windows 4 09-30-2016 01:09 AM
Pro Tools Control Won't Connect to Eucon award57 Avid S1, S3, Dock and Control App 6 09-11-2015 01:28 PM
Eucon Bypass Key Command on MC Control Problem KeyplayerG Artist Series 0 05-22-2015 06:10 PM
Pt10+Eucon 2.6.2+v-control po : hui problem ! klyg Pro Tools 10 4 11-18-2011 08:26 PM
Pro Tools 9 Euphonix problem controlling Sonnox EQ with eucon protocol Lars Krarup Pro Tools 9 1 11-12-2010 02:51 PM
