Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 05-14-2016, 04:48 PM
tifimartin tifimartin is offline
Default BFD ECO: Groove Looping Question
I am new to BFD Eco and Pro Tools, I learn fast but am basically a dry sponge right now. Anyway, I am trying to import a groove to Pro Tools which I have figured out how to do, problem is once I import into PT, the groove pattern only lasts for about 4 bars then stops. I need it to stretch for an entire song.
I can't figure out how to set the groove pattern to stretch for 3-5 minutes or so within BFD before exporting to PT, nor can I figure out how to copy and past the pattern in PT to achieve the desired length. When I try to copy and paste in PT in grid mode and use the grabber tool, the pattern either overlaps or doesn't leaves a gap.
Thanks to anyone kind enough to offer help.
Thanks,
Tiffani
Old 05-17-2016, 01:08 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: BFD ECO: Groove Looping Question
Can't you just duplicate it? Is the midi groove completely within the bar range you want it to be within?
If not, you may need to edit it a bit to make sure the notes are ending correctly. Then switch back to clip view and duplicate as many times as needed. Ctrl+D on Windows.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Groove Template Question Thrusby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-27-2012 08:09 PM
looping question Lynnweb7 Virtual Instruments 1 03-28-2011 03:04 PM
Simple Looping Question AirborneFO MIDI 6 06-18-2009 10:33 PM
Groove Agent and PT 6.4 Question Chromefree MIDI 0 06-08-2004 06:59 PM
Question about Looping cancedda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-05-2002 10:01 PM
