Old 10-30-2013, 01:59 PM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
Default Using Bonjour Browser to troubleshoot EUCON 3
EUCON 3 Bonjour Browser
There is a free tool that is very helpful when determining the source connection issues for EUCON 3.
Bonjour Browser: https://www.macupdate.com/app/mac/13388/bonjour-browser
There is a Windows version available also. Google Knows.
So here are the things to look for:
_euconproxy._tcp
- this is the service that Artist Surfaces use to connect to EuControl. In the image you can see My Artiwst Mix connected and it displays a link-local address (169.254.123.223). In this case it is set to use DHCP however it is connected via a switch so no DCHP is available. This is why you see link-local address.
- if surfaces are not connecting to EuControl this is the first place to check. If Bonjour Browser doesn’t see it, we won’t see it either and it is a network setup issue outside of EUCON world.
_eudof._tcp
- this is the big change from EUCON 2 to 3. These are the core elements that makes DAWs, Workstations and EuControl, etc talk to each other. This is not used for any Artist Surface connection but rather connecting to DAW and Workstations.
- in eudof there are various services to look for:
EUCON_MC
- EuControl on your local machine will appear as EUCON_MC.
- Any other instance of either MC App (the application that runs on MC Pro) EuControl on other machines will also appear here as EUCON_MC entries. The IP address tells you which machine it lives on.
- In the image you can see my instance of EuControl as EUCON_MC, it also has a link-local IP address (same reason as explained above).
EUCON_Node_Browser
- Any EUCON enabled Application on the network will create two instances of this. In this case I have ProTools 11 running locally only.
EUCON_Node_Observer
- this is created by MC_Client. It still runs in the background. This is needed to "see" the other EUCON nodes on the network. If this is not there you will not be able to see workstations or EUCON aware apps as EUCON nodes. In turn no EUCON connection when you focus on the app.
EUCON_Workstation
- This is also created by MC_Client in the background. This is what puts the workstation (local machine) on the network as a viable EUCON node for EuControl (or other EUCON_MC nodes) to attach to it.
- again if this is missing you will not have any app focus awareness, or EUCON connection to EUCON aware apps running on the workstation.
Old 10-30-2013, 03:55 PM
Default Re: Using Bonjour Browser to troubleshoot EUCON 3
Originally Posted by kdarbyshirebryant View Post
Thanks for this Daniel - in an amazing bit of synchronicity I had just downloaded 'Bonjour Browser' for Windows not more than 20 minutes ago to learn a bit more about all the zeroconf stuff on my network.
Make this a sticky?
Yup. Sticky would be good.
I post from Tapatalk so I'm not sure how. In fact no idea if I have those kind of powers around here. Lol
Old 11-02-2013, 10:36 AM
Top Jimmy's Avatar
Stuck as per Daniel's desire.
Parroted on my iPad with Tapasquawk.
James Cadwallader
Old 12-15-2013, 04:19 PM
Those of an iphone/iPad persuasion may be interested in the 'discovery - bonjour browser' app, a freebie on the App Store which displays bonjour services on your connected network.
Nice. Gonna try this out. I imagine It will only be helpful if the WiFi is on the same subnet as the EUCON network. Not hard to do and not uncommon on home routers by default.
Old 07-12-2014, 05:15 PM
KeyplayerG's Avatar
KeyplayerG KeyplayerG is offline
Make this a sticky?
Do you have a link for the Windows 7 Pro download version?
Old 01-22-2019, 02:06 PM
jgaz jgaz is offline
Just a heads up, this software has been updated/renamed to run on modern MacOS, is available through the apple/mac app store: https://itunes.apple.com/us/app/disc...81004916?mt=12
EuCon vs Bonjour on Windows 8.1 bonestonne Artist Series 6 10-31-2013 02:39 PM
Bonjour! Emcha_audio Le Forum en Français 0 04-21-2013 04:03 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
MC MIX PC: Bonjour/Input Director conflict DTSR Artist Series 0 03-01-2011 08:35 AM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
