Old 06-18-2013, 08:44 PM
darren051234 darren051234 is offline
Default Eleven Rack output in live situation, Bug or what?
Alright, i know most of you are studio based Eleven Rack user, so this might be a bit net picking, but I happen to use it live pretty much all the time when my band get gigs that can provide us a sound check, so i got a question would like to ask:
I play guitar or bass in a live situation, mainly play bass with it (suprisingly). and often live sound engineers would like me to give them a DI signal of the rack, and I either run a "1/4" out to amp" to a backline bass amp as my own monitor, or ultimately let the sound guy put it through the floor wedge, or all of the above.
I was just casual practicing in my bed room, with it hooked up to a floor wedge via the "XLR Main out", and realised that my eleven rack changes the signal path in the "Out to amp" menu.
if i chose one of the output to amp option to Rig Out no cab, it changes all my output with no Cab sims regardless what output path.
I couldnt find out why it does that: my floor wedge is connected with the main out, and the settings i change for the out to amp changes my main out settings as well.
this is really freaking annoying me, is this a bug, or have i misunderstand the function of "out to amp option"?
is there a way to have "Rig out" in my main out, and remain "Rig out no Cab" in my output to amp?
Thanks!
Darren
Old 06-18-2013, 09:19 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack output in live situation, Bug or what?
Are you saying you want full Rig Out on the Mains, meaning that the cab/mic is modeled, but you want the cab/mic bypassed for the Amp Out?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 06-19-2013, 11:40 AM
pierre.pan's Avatar
pierre.pan pierre.pan is offline
i'm french and i have the same problem, i'm very interested in any solution
11R, to rocktron velocity300 power amp (with the two output to amp), to cab1 and cab2. (stereo, output to amp1 to channel 1 of the poweramp and the nr 2 output to amp to the channel2)
and:
11r, to mixer (with one (or two) xlr main output), and amplified cab frfr.
so i don't want the cab sim on the output to amp,
but i want it on the main output (xlr)
thanks a lot
Old 06-19-2013, 11:50 AM
pierre.pan's Avatar
i precise,
on the output to amp i want the entire rig (with effects before and after the amp) exept the cab sim (as i put it bypass) and on the main output i want the entire rig with the cab sim
thanks again
Old 06-19-2013, 01:38 PM
Benoni's Avatar
If you all are setting the Amp Out to Rig Out No Cab, that will bypass the cab on all outputs, even the Mains.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-19-2013, 09:57 PM
pierre.pan's Avatar
yes, that's the problem, good sound in the amp or in the pa speakers, but the two together? perhaps it's not possible so i have to mic up the amp speaker and go to the mixer.
Old 06-19-2013, 10:16 PM
Yep, not possible to different settings, the cab is is either globally on or off. That has been discussed here a lot in the past and something that would be nice to have. I would not hold your breath though, I unfortunately suspect our beloved Eleven Rack software is not being worked on any more.
Darryl
Old 06-19-2013, 10:22 PM
Benoni's Avatar
Darryl
I'm not ready to write off the 11R yet. I'm waiting for the PT11 release to see how things shake out for this little orange box.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 06-20-2013, 12:45 AM
pierre.pan's Avatar
Hi, thanks for the answer, so i will mic up my guitar cab!
win 7, pro tools 10, eleven rack
www.pierre-pancracio.fr
Old 06-20-2013, 01:37 AM
When Avid announces an actual update or when Chris Townsend posts here with a hint he is working for Avid on anything new for the Eleven Rack (the eventual AAX GUI for PT11 does not count) I will buy you a case of beer Feel free to remind me at that time...
Darryl
Eleven rack Live problems. Angelo Bruschini Eleven Rack 0 09-18-2013 08:49 AM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
Eleven Rack in live situation (need advice) webstersp Eleven Rack 7 09-20-2011 05:50 PM
Live Recording of Eleven Rack Chad Pippin Eleven Rack 9 02-09-2011 11:16 AM
Eleven Rack Hiss when using live philster65 Eleven Rack 4 11-29-2010 09:08 AM
