Default plugin preset
Hi guys
This is a small problem, but is there a way to load my own presets as factory default when the plugin is instantiated? This would be very useful when creating a click track. Im on PT 7.4 Thanks Jakob
Did you talk to your talkbox today? |
Re: Default plugin preset
Hi Jakob; well i'm not sure if ur just speakin of a click track but u know that in the "TRACK" settings u can just click on "CREATE CLICK TRACK" & there u have it...
If ur talkin about an actual plug, u can just save ur presets & when u open the plug just click where it says "FACTORY DEFAULT" or som'n to that nature & ur presets will be on that scroll down...hopw this helps...
Hey Keybeeetsss
Thanks for your replay. Its not how I load the plugin or creating a click track thats the problem. The problem is how to save my own preset as the factory default presets so that my own preset loads automatically when the plugin is loaded. Hope this clear up things Thanks Jakob
ohhh...Ok well maybe some1 else knows that trick but as far as I know there isn't a way to do that; the way I described is the easiest as far as presets go...
How do you select a preset for a plugin? | Mike Landolt | ProControl, Control|24, Command|8 | 4 | 01-09-2008 07:46 PM |
Plugin preset switching | Snitz | Pro Tools TDM Systems (Mac) | 4 | 02-16-2006 12:52 AM |
Changes to the Protools Plugin Preset Co-op | tld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-06-2004 06:28 AM |
The Protools Plugin Preset Co-op | tld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-27-2000 08:40 AM |
The Protools Plugin Preset Co-op | tld | General Discussion | 7 | 10-17-2000 07:43 AM |
