Old 02-26-2024, 10:20 AM
BWV846 BWV846 is offline
Default Groovecell Patches
HI, Is it possible to individually configure the 16 pads to unique patches within the Groovecell menu list? I would like to select elements of different drum kits rather tan the one kit ensemble as presented. I couldn't find Groovecell .wav samples to link to, and don't have any sample libraries of my own.
(There are other drum samplers with different developers but I'm learning they all use their own code and not interchangeable).
Dell Precision 7510 i7 2.6Ghz Quad core, 32GB Ram, Windows 10 Pro 64-bit, Pro Tools Artist, Sibelius Artist.
Old 02-26-2024, 11:40 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Groovecell Patches
You can definitely load your own samples to each pad. Here is a link to the manual explaining how to do this.
You can also search around for free drum samples. The only requirement is they need to be.wav files. Here is a free pack from MusicRadar
Will
System Details
Old 02-27-2024, 01:02 AM
Sorry I was not clear; is it possible to load multiple different sounds from Playcells list of provided samples? I want to mix and combine drums from various samples supplied in Playcell.
Old 02-27-2024, 11:33 AM
junkgear's Avatar
I'm not sure if you mean PlayCell or GrooveCell samples, but either way, you can load samples of the file type .wav into the GrooveCell pads. Please see the manual linked above for instructions on how to load multiple samples into one pad.
If you are looking for the factory samples, you can find the GrooveCell samples at 'C:\ProgramData\Avid\GrooveCell\assets\factory_sam ples'
I would imagine the PlayCell samples are also under the 'C:\ProgramData\Avid' directory as well.
Will
System Details
How do I open GrooveCell? gng75 Virtual Instruments 1 08-06-2022 09:03 AM
GrooveCell Not Instantiating zspritz Getting Started 2 07-25-2022 07:16 AM
GrooveCell feedback clutch Virtual Instruments 0 06-13-2022 10:08 PM
GrooveCell bug? clutch Virtual Instruments 0 06-12-2022 08:41 PM
virus patches to indigo patches larry saldano Pro Tools TDM Systems (Mac) 5 10-03-2004 06:47 AM
