Old 01-11-2024, 02:55 PM
bscism bscism is offline
Default Multiple Midi/Instrument tracks slaved to a single instance of a virtual drum
I once read an article by, I think, Production Expert wherein they described how to build virtual drums tacks spread across a track for each kit piece. Editing in "notes" view it allowed to quickly pull together a drum track. The neat thing was that it all ran off a single instance of a virtual plugin, rather than having to load the same program across each track as you have to do if using the "split note" function.
But, for the life of me I cannot remember how to accomplish this and after spending the day trying to search for an answer I am about ready to give up. Before doing that I wanted to reach out in this forum to see if anyone knows how to do this. thanks.
Bruce
Old 02-05-2024, 03:14 PM
skylar_battles skylar_battles is offline
Default Re: Multiple Midi/Instrument tracks slaved to a single instance of a virtual drum
There're two aspects to this type of workflow. Multi-output audio and multi-channel MIDI.
What plugin are you trying to use?
The main thing is that to setup either of these things, you need to enable it from within the plugin first. It's very similar across samplers surprisingly. So once you've enabled multi-output audio, you can set the input of various AUXs to the plugin inputs cascading per element in the sampler.
For the multi-channel MIDI on the plugin input, once enabled from within the plugin, if on an MIDI or instrument track you select the appropriate MIDI channel from the plugin instance as the output, you can control the plugin from a track that it isn't on. You can also use all instrument tracks and use them to trigger different samples per MIDI channel and on those same tracks set the audio input for the multi-output audio from the sample you are triggering.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Can one midi or instrument track, trigger, multiple instrument tracks simultaneously? jamesleonard Pro Tools 2019 5 05-24-2019 07:33 AM
Multiple offline bounces of a single reverb instance simonchase Pro Tools 2018 4 03-14-2019 08:42 AM
Multiple Instnaces of VIs vs. multiple MIDI tracks targeting a single instance? kirkbross Pro Tools 2018 4 10-17-2018 05:30 AM
Using One Instance of VI Instrument for Multiple MIDI Tracks adam79 Virtual Instruments 9 12-23-2017 07:11 AM
Virtual Instrument - What is the Instance Number Howardk Pro Tools TDM Systems (Mac) 1 04-12-2005 01:15 AM
