Old 05-22-2019, 03:03 PM
kkfaudio kkfaudio is offline
Default Sync HD losing dropping lock
Sync HD using Video REF.
Ref Present light staying lit, but Speed Cal and Locked lights fluctuate quite a bit, and will often disappear long enough and I get:
"The SYNC Clock Reference is not locked. Although the system will still play, it will not properly resolve until the clock is restored. Check your cables or change the Clock Reference or Clock Source."
It usually resolves itself quickly. The reference and loop sync cables seem fine - although I have not swapped the serial cable as yet, as it's hard to get to on the Mac. Is it possibly that cable, or is my Sync HD being faulty?
Thanks!
Kevin Ferrier
Audio & Sound Design
www.trianglepost.com
Old 05-22-2019, 04:53 PM
dr sound's Avatar
dr sound dr sound is offline
Default Re: Sync HD losing dropping lock
Check your reference. Make sure your reference and your session are the same.
23.98 reference and 23.98 session
24 reference and 24 session.
They may lock if it's different but it won't be right.
MAKE SURE WHAT YOUR REFERENCE IS!
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 05-22-2019, 05:31 PM
dr sound's Avatar
What is your Video Reference? What is the origin of it?
Check the devise and verify it's the same as your session..
23.98 or 24 frame.
aka dr.sound
www.thedubstage.com
Old 05-22-2019, 08:12 PM
Ray JB Ray JB is offline
A quick question, do you have a 75 Ohm video terminator on the loop thru BNC socket of the sync ref input on your Sync HD? Mine used to do that even with the correct reference signal if un-terminated
Old 05-23-2019, 01:26 AM
Yes, what Ray said. The video ref out is a passive through and needs to be terminated.
PTHDn 2019.5 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 05-23-2019, 04:12 AM
Thanks for the replies..
I forgot to mention the video ref continues on to the Aja Kona 3 breakout box.
I will have to check that it is terminated properly there. Any reason to swap the order? ie ref to Kona and then sync HD? I don’t see any blips in Aja control panel.
Yes, I definitely check that the correct reference is setup according to frame rate in the session.
I’ll follow up next week after I get back to that room.
Kevin Ferrier
Old 05-23-2019, 04:28 AM
Just put a 75 ohm terminator at the end of the video ref chain. The Sync HD is finicky with the feed it gets. The manual states that you need to terminate the end of the chain properly for correct operation. Believe me, it's generally needed.
Old 05-23-2019, 08:29 AM
Copy that - I'm 99% sure it is terminated, but I'll take the Aja out of the loop and terminate on the Sync HD for testing and go from there...
Thanks..
Kevin Ferrier
Old 05-23-2019, 11:21 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
You might want to check if your Sync HD is well cooled as its very sensitive to higher temperature.
Does this happens at the morning when the unit is cold?
I had the same problem with my Sync HD in conditionered machine room until I made some room above and beneath of Sync HD in order to be well ventilated.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2018.12 Ultimate ● macOS High Sierra 10.13.4
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 05-27-2019, 06:41 PM
Kevin, did you sort your problem? If so what caused it?
HTML code is On
Dropping sync after 6+ hours lucienpalmer Post - Surround - Video 5 11-07-2015 07:10 PM
HD system dropping out of sync decibelmel Pro Tools TDM Systems (Mac) 0 10-25-2003 01:14 AM
Pro Tools dropping out of sync ever since HD uno1234 Pro Tools TDM Systems (Mac) 26 05-31-2002 06:50 PM
my mac dropping into number lock in pt tomcat Pro Tools TDM Systems (Mac) 1 10-14-2001 04:09 PM
PT and USD dropping out of sync!? Boom Chic Pro Tools TDM Systems (Mac) 5 02-12-2001 09:10 AM
