Old 12-06-2015, 06:02 PM
Soldano Soldano is offline
Default Disk Cache in PT12 any opinion?
Hi There
How is your opinion on upgraded disk cache function in Pro tools 12.Does anybody experienced some good results with it?How does it work?Can I think about this like when I have 16 GB RAM and in theory can use +-12 GB for Pro Tools ...let say all audio files in the session are about 10 GB big so will they be fully loaded into RAM(as it said RAM is always faster than Hard Disk and anyway it's better to keep all audio files on different disc dat system/Pro Tools disc.How's your opinion does CPU power and overall PT performance feels beter to you?I'm still on version PT11 that's why I'm asking.
Regards
Old 12-06-2015, 07:07 PM
Southsidemusic's Avatar
Default Re: Disk Cache in PT12 any opinions
As we have always used PT HD we use Disk cache all the time. The session starts faster than you can blink and when weare on the road at hotelrooms and whatnot we don't need a secondary drive to record to as Disk Cache wirks for you and loads up the bulk of the sessions into the RAM. If you have 8 GB you can assign 5GB for DC and if you have 16 GB you can atleast use 12 GB of the RAM which is A LOT! for a session. Usually we only end up using a few GB and PT reminds us that we have a lot of unused DC RAM so this is a killer feature to be had on the vanilla PT 12 version, really saves a lot of headache and hassle if you need to run out the door with just the ilok and the Macbook
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-07-2015, 10:21 AM
mirovaz mirovaz is offline
Default Re: Disk Cache in PT12 any opinion?
I'm loving it! Asked this to the Native PT a long time ago.
Cheers!
MacBook Pro M1 16G RAM
OSX Big Sur 11.6
ProTools 2021.10
UA OCTO Thunderbolt, UAD Twin MK2 QUAD
Old 12-08-2015, 03:32 AM
Blackers Blackers is offline
Very interesting,is there any tutorial about how to do this in a native windows?Thanx
Old 12-08-2015, 03:59 AM
Stig Eliassen's Avatar
Go to Setup (menu) > Playback engine. You'll find it at the bottom of that window. I have it set to 5 GB. There's really nothing more to it.
Old 12-08-2015, 05:11 AM
ha ha thanx!!!!
Old 12-08-2015, 07:17 AM
The Weed's Avatar
The Weed The Weed is offline
But, if you don't have PTHD, you need the version of PT12 disk cache was added to or later. Definitely in PT12.3.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-08-2015, 12:44 PM
Yessss sir Weed,i just did it.Thank you
Old 06-16-2016, 08:43 AM
Rob L Rob L is offline
Hi folks, new to the forum; not Pro Tools.
I've started using the disk cache function in PT12 native and with impressive results so far.
What I've noticed, whilst experimenting, is that the automatic session file backups stop when disk cache is on. I have some ideas as to why this could be (less disk activity!)
I was wondering if anyone else has had the same experience?
Cheers!
Old 06-16-2016, 09:12 AM
Cheers!
Not here - always running with cache on, auto backups happen as scheduled.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
Where's the Disk Cache sofakat Getting Started 12 06-27-2013 04:10 PM
Disk Cache Bug in PT 10.3.3 zion Pro Tools 10 51 03-12-2013 04:26 PM
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? sunburst79 General Discussion 6 09-15-2011 11:28 AM
