Old 02-25-2006, 06:59 PM
kcurry kcurry is offline
Default LE Latency
Hi. I'm considering purchasing an LE system (like the 002 or 002R), but I'm a bit concerned about the issue of latency during recording. I see lots of good things said about the systems, but I also see people complain a lot about the latency. I would be curious to hear input from users of these systems. Thanks.
Old 02-26-2006, 04:21 PM
Default Re: LE Latency
There are 2 solutions to latency with the 002. First, low-latency mode makes it a non-issue BUT you give up the ability to use plugins and aux sends on your record-enables tracks. The work-around is to double-assign using aux tracks with plugins so you can for instance, hear verb on the vocals while tracking. The other and better solution is to use a real powerhouse machine (like the Allenstein "Best Desktop" or a high-end MAC so you can work at 128 buffer setting while recording. Once you are done with tracking, up the buffer and lay in all the plugins you need.
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Piano VI's- Latency Latency!! MARVINBASS Virtual Instruments 5 04-27-2006 01:09 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
