9129 Errors
So, please forgive if this is the wrong forum for this. Any help for the right environment would appreciated.
I'm basically having the same problem over and over with the errors -9129, -9092 and -9093. I've been through the entire site and threads and made pretty much every adjustment and tweak that has been suggested, but still have the problem. I'm running on a Inspiron 5150 laptop. I have included a summary of my system below. As a recap, when I set the H/W buffer to 512, I get the -9092 and -9093 errors...pretty much immediately upon playback of my track. If I set it to 1,024, I get the -9129 error after a couple of minutes. The session I'm using right now is nothing fancy and not a lot of tracks, 6 max. I'm running Pro Tools 6.9 and have an MBox system. It's frustrating, because Pro Tools is currently unusable for me, as I cannot get it to do anything reliably. Please help! My system specs are below. Any help would be greatly appreciated. Thanks! Mike [email protected] SiSoftware Sandra System Host Name : MIKERS-LAPTOP User : Mike Domain : MSHOME Processor Model : Mobile Intel(R) Pentium(R) 4 CPU 3.06GHz Speed : 3.06GHz Performance Rating : PR4066 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile Internal Data Cache : 8kB Synchronous, Write-Thru, 4-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector Mainboard Bus(es) : ISA AGP PCI IMB PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : Yes System BIOS : Dell Computer Corporation A36 System : Dell Computer Corporation Inspiron 5150 Mainboard : Dell Computer Corporation Total Memory : 512MB DDR-SDRAM Chipset 1 Model : Dell Computer Corp 82852GM/GME/GMV/PM, 855GM/GME Montara Host-Hub Interface Bridge (A2-step) Front Side Bus Speed : 4x 133MHz (532MHz data rate) Total Memory : 512MB DDR-SDRAM Memory Bus Speed : 2x 166MHz (332MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce FX Go5200 Physical Storage Devices Hard Disk : HTS548040M9AT00 (37GB) CD-ROM/DVD : _NEC DVD+RW ND-6100A (CD 24X Rd, 24X Wr) (DVD 3X Rd) Logical Storage Devices Hard Disk (C:) : 37GB (18GB, 47% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C2 USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C4 USB Controller/Hub : Intel(R) 82801DB/DBM USB Universal Host Controller - 24C7 USB Controller/Hub : Intel(r) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24CD USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Texas Instruments PCI-4510 CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse MultiMedia Device(s) Device : SigmaTel C-Major Audio Communication Device(s) Device : BCM V.92 56K Modem Printers and Faxes Model : Microsoft Office Document Image Writer Model : Auto hp photosmart 7700 series on FAMILY Model : Auto HP DeskJet 640C/642C/648C on JEANNETTE-01 Model : Auto HP DeskJet 640C/642C/648C on FAMILY Model : Auto Epson Stylus COLOR 660 ESC/P 2 on D756B641 Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600 (Service Pack 2) Network Services Adapter : Dell Wireless WLAN 1350 WLAN Mini-PCI Card Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: 9129 Errors
Hi!
You might try the PT LE for XP section- they have several threads with laptops and such going.
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Re: 9129 Errors
Thank you Nikki!
-9129 errors??? | PT user | Pro Tools HDX & HD Native Systems (Mac) | 0 | 10-11-2012 01:25 PM |
-9129 errors & 10.3 | PT user | macOS | 8 | 10-02-2012 03:47 PM |
9129 Errors | jjhuntfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-11-2006 10:12 AM |
9129 errors - PLEASE HELP!!! | N33lan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-28-2005 05:18 PM |
Getting 9129 errors w/ PT LE 5.1 | sfahlsing | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-04-2004 11:50 AM |
