Which audio card to replace the 003 rack+
Hi the 003 rack+ is no longer compatible with pro tools 12.8, which means I will have to replace it quite soon. Which external card would you recommend to replace it? I do NOT have pro tools HD ...I need a very good sound and a 96KHz recording possibilty but I do not need a lot of inputs ...2or 4 microphones inputs with preamps....and most of all : no latency !
I am using windows 7 pro A pc with Intel core I5 with 8GB Ram Thank you for your inputs...I am a bit lost!! |
Re: Which audio card to replace the 003 rack+
RME Babyface Pro or UCX. Of course, you need a decent budget for these.
MOTU has some good stuff. Very solid
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
Yes but those have the gain control in the computer, I'd rather have those on the card itself....but they are in my price range...
Do you think an Antelope Zen studio would work with pro tools? There is no reference to it on this site
With certain MOTU interfaces you can control things via the front panel. Not easy but it can be done. I'd suggest one of the MOTU 828 boxes; some of this is going to depend on what you have on the computer as to interfaces - USB2 or Firewire.
With Avid, "is not supported" and "does not work" are two different things. The 002 has not been supported for years, but still worked. "Is not supported" basically means you're on your own and the transition to "does not work" can happen any time without notice. If you've been happy with the 003, try the 003 with 12.8 and see how you do before any new purchase.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
If the 003 is selected in the Windows Sound control panel (not even sure there is a 003 WDM driver), that could be the reason it's limiting you to 44k. If so select something else.
No it's not selected in the Windows Sound Control panel... |
DIGI 002 Rack seems to be out... what to get to replace? | hotburgers | FireWire & USB Audio Interfaces (Mac) | 5 | 07-06-2016 02:54 PM |
Anyone replace Control 24 ethernet card ? | Petander | ProControl, Control|24, Command|8 | 2 | 03-30-2016 10:58 PM |
Does Eleven Rack replace 002/003? | teacherman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2010 08:56 AM |
Replace sound card with firewire? | Idahoguide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-12-2007 12:16 PM |
002 Rack to replace soundcard | SSE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-30-2003 10:35 PM |
