Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-27-2017, 03:47 PM
dsetto dsetto is offline
Default Re: 003 Control Surface Logic Pro- Let's Do This
P.S.
In that previous attempt, there was no controller "installed" in Logic Control Surfaces "Setup".
Those Controller Assignments were simply added. They were created by editing Learned Assignments.
Old 03-27-2017, 04:06 PM
Good news is with a system restart, the one-way 003>Logic, 16 Fader control remains as before.
And, if I add to or remove one of the "unassigned 8 header", assignments shift as expected. And, if I add a track beyond the controllable 16, control cannot be established. This is expected because 003 in MIDI Mode transmits on MIDI Channels 1-16. I will assume this, 16 tracks, is the limit for the 1-way 003>Logic control.
So, at worst, I have a non-dynamic 1-way, 16-Fader (in 2 banks) control of Logic.
Old 03-27-2017, 04:11 PM
It seems those Logic Controller Assignments are essential for this.
Old 03-27-2017, 05:18 PM
Mute and Solo are a mess. I've got them on the correct 16 Fader>Track correspondence.
Issue is:
Two clicks of the 003 button are necessary to equal a signal to Logic. So, the mute or solo lights on 003 so not correspond with mute/solo status in Logic. Real mess. Pretty much useless.
On 003, I can choose between latch or momentary. But, latch is only one that makes sense.
In Logic, I tried all sorts of combinations but could not get the desired 1 003-Click to 1 Logic response ratio. (It's 2:1)
Panning works perfectly.
What a mess.
Old 03-27-2017, 05:42 PM
Transport works.
003 Control Surface with Logic 9 MichaelAS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-18-2009 06:05 AM
how to use 002 for control surface in logic pro 8? Help!! Tympanic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-26-2007 08:27 AM
using 003 control surface with Logic Pro Juraj Bernáth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-19-2007 11:41 AM
002 control surface w/ logic? Amo Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-19-2005 11:53 PM
1 CONTROL SURFACE FOR BOTH PT & LOGIC ? DooDooDoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-06-2003 03:05 PM
