Old 03-05-2004, 11:11 PM
MusSickIzLife MusSickIzLife is offline
Default Installation Error!!
Okay, it goes like this.... I've been waiting to get the 001 box for SO LONG.... and finally, after months and months of waiting... I GET IT.. Now for the problem. I pop the PCI Card in, following all the directions in the book. And I start up the computer. The "New Hardware found" pops up, so I proceed, following exactly what was in the book, and I hit "Have Disk" and direct the computer to the exact folder I was supposed to. So when I hit "Next" It goes to a screen that says "There was a problem installing this hardware 'DigiDesign Digi 001' an error occured during the installation of this device"... And no matter how many times I do it, i still get this message. Whatsup with that and how do I fix it?
PLEASE HELP ME!! SOMEONE!!
Old 03-06-2004, 01:32 PM
Default Re: Installation Error!!
If it helps any, this is how my system looks....
CPU: Intel P4 2.6 GHz
Motherboard: Soyo P4 Approved
Memory: 512 MB DD
Hard Drive: 120 Mb HDD 8Mb cashe
Soundcard:S/B Audigy PCI
OS: Win XP Home Edition.....
Old 03-06-2004, 07:40 PM
Whats going on? Nobody's ever seen this problem? Can I get some potentials? Something that MIGHT be the problem? This is really urking me. Can someone help me please?
Old 03-06-2004, 10:33 PM
jjhuntfox jjhuntfox is offline
I don't know if anyone else has used this motherboard....
You might try removing soundcards / firewire cards and see if that helps.. Is it 6.1 that you are trying to install? Might get the 6.1.1 update. Also try updating drivers for MOBO / Video Card etc.
Otherwise you may have to try tech support. Sorry I don't have anything better for ya.
John
Old 03-06-2004, 11:30 PM
Actually, it's 5.3.1.... Man, this is giving me the biggest headache.. I tried calling Tech Support from the number that was in the book, and it wouldn't go through
Old 03-06-2004, 11:42 PM
KingFish KingFish is offline
Try installing the 5.3.1 wav driver, manually from the CD first, if I remember, it may be under Beta software on the CD.
Hopefully this will force windows to recognize the digi hardware, thus "showing the way" to PTLE
Install the wav driver, re-boot your machine, check in your control pannel, under sounds and audio devices, and see if Digi 001 1&2 is an option under "Audio" and "Voice"
If it is....
Then select it, hit apply, ok, and try installing PTLE 5.3.1
Good Luck
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 03-07-2004, 07:08 AM
King, it didn't say anything on the CD about Beta......... I looked throughout the whole thing. Could it possibly be somewhere else on the CD?
Old 03-07-2004, 02:19 PM
Hey guys thanks for all the support, luckily i did find the problem. The 5.3.1 edition i had was only compatible with Windows ME and 98SE... Since i'm running XP it didn't work... Luckily I found all the right drivers, and everything went smooth... Thanks all, Mike
PT installation error**HELP PLEASE** Almanist Eleven Rack 2 05-28-2011 11:13 AM
error message during installation error 2147213312 pianovasano Pro Tools M-Powered (Win) 1 08-31-2010 07:52 AM
Installation Error tylerhole Pro Tools M-Powered (Win) 1 06-27-2009 10:57 PM
Win XP Installation error ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-03-2007 07:54 AM
Installation error abbaspremjee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-19-2007 11:06 AM
