Old 08-12-2019, 08:34 AM
joachim's Avatar
joachim joachim is offline
Default AAF , Tempo "varies" and Assertion Error, Import impossible
Dear members,
I recieved an AAF (24bit, 48kHz, 25fps) with embedded audio files, made with Media Composer.
Upon importing, the following error message comes up :
"Could not complete your request because Assertion in "..\ ..\ FF\ Audio\ FF_AudioFile.cpp", line 1000."
The individual references to audio files appear on my timeline.
In the workspace browser, there are no offline files, just the AAF itself.
Conspicuous : in the meta data of the AAF, item "tempo", it says "varies".
Could this be some "unrendered" pitch/elastic audio effect, some tempo change in the video edit session, that inhibts PT from importing, since it cannot guaranty synchronicity ?
How can this befixed by the video editor (by me) ?
Thanks in advance,
J.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 08-12-2019, 08:35 AM
joachim's Avatar
Default Re: AAF , Tempo "varies" and Assertion Error, Import impossible
A screenshot of the AAF Export Settings.
Old 08-12-2019, 06:22 PM
reichman's Avatar
reichman reichman is offline
Whenever I see an "assertion error" I trash Workspace files and it goes away:
http://avid.force.com/pkb/articles/t...nd_Preferences
Does that help?
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 08-13-2019, 12:53 AM
joachim's Avatar
No, same error message, same result.
Old 08-13-2019, 12:06 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
To narrow the issue down try an AAF from a MC timeline that has just the clip that has a pitch/elastic audio effect, on it to see if it has the same error.
If that shows the same error then you could try making an audio mixdown of just this clip and effect. Make another AAF with just this mixdown. Could lead to a workaround for you with the MC timeline.
Andrew
Old 08-13-2019, 12:35 PM
joachim's Avatar
I am unfortunately not in the position to ask the/a MC video editor for a test series.
This specific MC video editor assured me today, he used some slomo sequences. But all this gets rendered to 24bit/48Khz/25fps upon AAF-creation, right ?
"Tempo" "varies" in the meta data of the AAF : normal ? ever expirienced ?
Old 08-13-2019, 01:01 PM
BScout BScout is offline
Only if you tell it to render all effects for the AAF. It doesn't do it automatically.
Old 08-13-2019, 01:12 PM
joachim's Avatar
Post #2 , Screenshot: "render all audio effects" was marked.
Old 08-13-2019, 07:21 PM
smurfyou smurfyou is offline
I don't usually get embedded AAF's from MC, just referenced, so I'm just guessing here. Do you need to check the box "Convert Audio File Format to Wave"?
I've had trouble with AMA linked media but I think that usually shows up offline not throwing an error.
~Will
Old 08-14-2019, 06:04 AM
joachim's Avatar
This is what I get upon import, no changes made :
HTML code is On
Error Messages- "Read Only" & "Assertion" KimmieMcD33 macOS 4 05-23-2017 03:20 AM
Assertion Error on "Save as" leading to crash when session closed aaarrrrghhhhhh Pro Tools 12 1 03-10-2017 12:19 PM
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? nickbradbury macOS 13 09-10-2014 03:50 AM
"Import Session Data" tempo issues GJV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-08-2009 05:57 AM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 09:38 AM
