Old 06-12-2008, 04:34 AM
Taliq Taliq is offline
Default \"Select unused\" in Region List also selects \"Used\"
When I try to clean my Session in Region List, "Select Unused" also selects all my whole Audio Files still in the Arrangement but not the Regions chopped still in use. "Select Unused except whole Audio Files" is not working for me because I want to remove/delete whole Audio, but NOT the ones in the arrangement. So I have to select all the Audio Files myself I want to remove/delete.
Is there a way to solve this or a workaround?
I'm working on HD 7.2.
Studio:
PPC G5 Dual 2.7GHz, 4GB DDR SDRAM, Mac OS 10.4.6
Pro Tools HD 7.1, 6 DSPs, 4x192 i/o
SSL 9000 J-Series
Private:
MacBook 1.83 GHz Intel Core Duo, 1GB DDR2 SDRAM, Mac OS 10.5.3
Pro Tools LE 7.4.2, MBox
Old 06-12-2008, 05:05 AM
tclash tclash is offline
Default Re: \"Select unused\" in Region List also selects \"Used\"
Well, unless you consolidate all your edited regions into whole audio files, that's pretty much how you have to do it.
Old 06-12-2008, 05:09 AM
Sigh....PT and maintenance. A sad story.
There are many lacking options to clean up sessions. There´s also no option to remove only the regions that are offline AND unused but not anything else. Just to mention one other example.
frank.
Old 06-12-2008, 05:15 AM
Snitz Snitz is offline
1 - sekect "all unused except whole files", Shift-Command-B, Remove....
2 - select "all unused" any highlighted whole audio that has NO regions listed below it (is not used in session) can be deleted.
Old 06-12-2008, 06:07 AM
3- then hand-deselect (maybe hundreds) of regions and make sure you don´t let go of the apple-key or you´ll have to start over with de-selecting.
Old 06-12-2008, 07:17 AM
bad jitter bad jitter is offline
Another lacking option is to be able to select all muted regions (to remove them). Doing it now by hand at the end of every project before archiving.
Old 06-12-2008, 07:18 AM
Hence all the 24-track, three minute indie songs that are 10gb files
Old 06-12-2008, 02:34 PM
Let me explain the situation in detail.
After recording and editing is done, the merged files are imported to Pro Tools because it has been recorded in Logic. The silence is then cut out because of disc usage. After mixing is done, I re-record the master mix and several stems on Stereo Audio Tracks that are consolidated right after to have the same start. It doesn't have the same start because I'm using a SSL desk as master.
Now there's the problem I try to solve. When I select "select Unused" Pro Tools selects all the recorded audio files as they were before consolidating, but also all audio files used for the mix. Selecting "select unused except whole audio" wouldn't select the files I want to delete/remove.
I hope this helps you a little bit helping me.
Studio:
SSL 9000 J-Series
Private:
Old 06-14-2008, 07:06 PM
Is it possible, that Pro Tools keeps the file reference even if the audio file ist not in the regions list?
Studio:
SSL 9000 J-Series
Private:
Old 06-16-2008, 04:54 AM
TCDet TCDet is offline
Prior to console mixing I consolidate all tracks to be mixed.
(File names will match the track names.)
Select Unused>Clear selected (Remove or delete)
Works here with V 7.3cs? & 7.4.1
Path (Pt's>SSL x64 wide>Mix-Stereo>Apogee-200> PT's Mix Track)
You may look at your files full path in the regions bin for trouble shooting.
Check OS & PT's Versions trash all the recomended trouble shooting pref n such.
? Are you using the Compacting in the regions bin or consolidating in the edit window. (For my above example I consolidate in the edit window).
select a single region with the grabber tool selects all regions dinzer47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-22-2019 01:15 PM
8.01 Region List Unused Clearing problem TimNielsen Pro Tools TDM Systems (Mac) 8 09-02-2010 03:39 AM
"Select Unused Regions" selects USED regions. Please help.. pukeuv Pro Tools TDM Systems (Mac) 9 04-26-2007 02:04 PM
Remove unused audio tracks from region list MaLa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-11-2005 02:47 AM
Protecting unused regions from being Deleted in Region list BboY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-03-2001 12:35 AM
