AAF import broken in 6.7 (all the way up to cs8)?
Just upgraded from 6.4 to 6.7 and it looks like you can no longer import AAF files. 6.7 (up to cs8) won't import AAFs previously exported by 6.4 or new AAF files exported by 6.7. OMF files seem to work fine. Anyone else having this experience? Any workarounds (besides OMF)? What's the best way to report the bug to Digi?
Thanks, Jason www.chromasound.net |
Re: AAF import broken in 6.7 (all the way up to cs8)?
http://www.digidesign.com/support/forms/bug/
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
AAF import is working fine here. Do you own Digitranslator or DV Toolkit? When you say "won't import" do you mean that you not able to select the AAF? Is an error message posted? Does the import appear successfull but then the tracks are not displayed? Please describe a step by step example of the problem. regards, Digidesign Technical Support |
I do own the DV Toolkit. Steps to reproduce:
1. Select Import Session Data 2. Choose existing AAF (known to import correctly in 6.4.1) 3. Go through import dialog, select destinations as new track Results: Import completes. New tracks show up, but contain no audio regions. I can send example AAFs if it will help. Other info. The LE session has 44 tracks, a mix of audio, MIDI and auxes. This is on OS 10.3.7, dual 2.5 G5 2.5G RAM. Thanks, Jason www.chromasound.net 206-250-8180 |
le session can not have 44 audio tracks,
do you mean 44 with aux included? aren't the audios in the region list? or they appear as missing files? when you said 6.4.1,you're not talking LE
so what |
Does your AAF contain any embedded media? Does it reference any SDII files?
If you create a new session, record 10 seconds of silence on a new track and export that as AAF, can this be imported back into the session successfully? regards, Digidesign Technical Support |
That works fine. Something else is going on. Trying to import these AAFs into this new sessions give me "7 audio files missing" message. Something else is going on. I'll look deeper...
Thanks, Jason |
Interleaved Import Broken? | dwaynedelario | Pro Tools HDX & HD Native Systems (Mac) | 2 | 01-12-2013 08:27 AM |
Strike sample import? v1.5 broken | magnoman | Virtual Instruments | 1 | 03-30-2011 06:16 PM |
Import samples Strike 1.5 broken? | magnoman | Pro Tools TDM Systems (Mac) | 0 | 03-30-2011 06:19 AM |
Import Session Data broken?? | ilovemyssl | Pro Tools TDM Systems (Mac) | 2 | 04-06-2007 04:25 AM |
CD import broken, help | Richard Fairbanks | Pro Tools TDM Systems (Mac) | 6 | 12-28-1999 01:01 PM |
