Old 03-01-2002, 08:37 PM
Ajay Ajay is offline
Default PC Probe problems. Any overheatingg problems with Digi 001
Has anyone had trouble loading the PC Probe software on their computers. I downloaded the latest version and it said the same thing the last version said (Can't find Lm procedure. Any feedback would be helpful. Also has anyone had any problems with overheating when running Digi 001? What type cooling would you guys recommend? I am currently using a Volcano 7 for my 1600XP CPU.
Thanks
Ajay
Old 03-02-2002, 04:38 PM
Stone Knife Stone Knife is offline
Default Re: PC Probe problems. Any overheatingg problems with Digi 001
I am running 5 fans in my machine:
-one 18mm Panaflow intake w/ filter right in front of the 2 hard drives
-one Processor fan
-one Power supply fan
-one video card fan (on the geForce 3Ti)
-one pci-slot blower exhaust fan directly below the GeForce fan so they are face-to-face.
The machine is enclosed in an iso cabinet because it does sound like a power sub-station when the door is open.
The primary hard drive runs @ between 79 and 83 degrees when ambient room temp. is 70, no matter what the load. No difference between Echo Mia and Digi 001 (from my hard drive sensor, anyway.) I guess I could add a probe at the exhaust blower, just for fun...
(I use a Sunbeam electronic thermometer with a wired sensor mounted in the center of the primary HDD)
Old 03-03-2002, 04:33 PM
Rabidium Rabidium is offline
Oki, I've had a similar problem with loudness, I'm only running an Athlon 1400 but it sounds like I'm running a Boeing 747 in my studio.
So, what is an ISO Cabinet? Will this quiet up everything? Where do I get it?
Thanks,
-Olaf
I guess I'm back.
www.byOlaf.com
Old 03-03-2002, 05:08 PM
8mmOverdose 8mmOverdose is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Rabidium:
Thanks,
-Olaf
<HR></BLOCKQUOTE>
iso = isolation cabinet. basically you put your computer inside a bigger box with foam inulation in it. shouldnt be hard make your own.
Old 03-03-2002, 05:30 PM
Mark_Knecht Mark_Knecht is offline
I'm running the A7V266E with a 1600+. I reduced the noise a lot by purchasing a new Silencer 275 power supply from
http://www.pcpowerandcooling.com
I went with the 275 Watt supply since I only have one internal hard drive. (Audio is 1394) I run only the supply fan and the two on the motherboard, and I can say now that the bulk of the noise is the processor and chipset fan. The power supply is quite quiet. (No silent, but quiet!)
Take care,
Mark
Digi 002 and PT9 problems Phox Pro Tools 9 3 11-21-2010 06:49 PM
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
digi 001 problems nightshadecrisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-23-2003 11:47 PM
Is there a PC for Digi 002 that WON'T have problems?? SJSJR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2003 11:15 AM
Digi 001/PT LE G4 500 Problems! byteme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-15-2000 03:50 PM
