never had to deal with latency issues
I guess when I started with pt 7 mpowered and the maudio interface, I started wiring everything differently, and have never had to deal with latency issues if I play it right in the pt daw. Today I have PT 12.6 and a PreSonus StudioLive AR12 USB interface. I wire it up the same and have no latency issues.
The output playback goes through the interface and out a channel on my PreSonus board I've labeled 'playback'. My mic goes from my pre73 into a comp3a and into a random channel on the PreSonus. I eq the signal a little and direct it as a monitor send and then run that monitor signal into another channel, usually no 1, where it goes into the daw. The sound a vocalist, for example will hear, is his vocal through the board (not from going to the daw and back through the playback) and the playback media that's already been recorded coming through the playback channel. When I use 'input' or 'record' buttons on the pt track, I also use the mute button in the daw. This mute keeps the signal from coming back through the playback and creating latency with the channel 1 direct output. The only trick for me is when someone wants to punch in. I unmute that pt track so they can hear the previously recorded material, and quickly mute it while they punch in during the punch in selection, so that they don't hear latency while they sing. So it's an extra button to click, but no latency issues!
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
Re: never had to deal with latency issues
What's your buffer setting? Set it to 64 and monitor from the session(instead of the console) I've not used the Presonus, but my older setup with DIGI003 never had any latency issue as long as I did 2 things:
1-set the buffer to 64 for tracking(any modern computer should handle this within reason) 2-avoid tracking with high-latency plugins(very easy to do)
LE to HD......Whats the deal with latency? | The Dougfather | Pro Tools TDM Systems (Mac) | 6 | 08-17-2010 01:05 AM |
What's the deal with MIDI latency? | Starcrash | MIDI | 3 | 03-29-2008 05:39 PM |
best way to deal with recording latency | skylab001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-07-2006 11:57 AM |
Best way to deal with plug-in latency. | Droog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-08-2006 10:00 AM |
What's the deal with the 'latency' thing?? | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 03-22-2004 12:55 PM |
