Old 03-14-2006, 07:32 PM
Bermaster Bermaster is offline
Default Installation problems
I am having a hell of a time installing my M-Audio FW 410. I followed the directions a hundred times and I am still stuck. This is the process I have been following:
- Download latest FW 410 driver from M-Audio.com
- Install drivers
- Shut down computer completely
- Connect Firewire 410, switch power on
- Restart computer
... nothing
No "new hardware found". I have tested this on 2 different computers and get the same results. The power LED on my device is a quick consistant blinking.
Anyone? Please?
(I am a very experience user. Long time Pro Tools LE user (001, 002, 002R, Mbox) and Computer Science graduate.)
Brian Berman
www.brian-berman.com
Digi 002, Pro Tools LE 7
Old 03-14-2006, 08:55 PM
Mozepy Mozepy is offline
Default Re: Installation problems
And nothing shows up in the Hardware Manager?
If not I would say defective device, cable or port.
Unless your Plug and Play service is disabled.
Old 03-15-2006, 07:16 AM
Plug and play is up and running. Both my iLoks showed up. Tried multiple cables and multiple ports (and multiple computers).
Bad device?
Brian Berman
Old 03-15-2006, 08:07 AM
The FW 410 may be defective. Did you talk to M-audio tech support?
Old 03-15-2006, 08:27 AM
I haven't contacted them yet. I wanted to see if anyone had any ideas first. Thanks.
Brian Berman
Old 03-15-2006, 08:45 AM
jeff markham's Avatar
jeff markham jeff markham is offline
well, i was gonna help you tell you admitted your a CS graduate ;-) .. j/k ..
i'm a techgeek too.
i think that flashing LED is not a good sign. i've got a FW1814 .. the power light
comes on ..as the computer boots .. all LEDs light, go out .. and then each led lights
in-turn in a pattern. the only time i get a flashing LED is when it can't find a word
clock (sync problem with external clock).
i assume you've used your FW interface for other devices? i'd start simple ... and
eliminate the obvious .. bad cable, power, firewire interface, etc.
a bummer for sure.. ;-(
jeff
Old 03-15-2006, 10:00 AM
Thanks. Tried multiple cables, fw cards, computers, etc.
Looking like a bad FW 410.
Brian Berman
Old 03-15-2006, 12:53 PM
that's a drag .. it's first time i've heard of M-audio
stuff showing up DOA .. ;-(....
best wishes on the return rigamorro
Installation problems Mickstape Productions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-15-2009 01:11 AM
Installation Problems...Please Help Me! Chad Pippin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2009 01:47 AM
Installation Problems inlimbo21 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2008 07:47 AM
Installation Problems MikePhilippov 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-14-2006 02:04 PM
help please! installation problems. jday 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-14-2005 08:14 AM
