Installation problems
I am having a hell of a time installing my M-Audio FW 410. I followed the directions a hundred times and I am still stuck. This is the process I have been following:
- Download latest FW 410 driver from M-Audio.com - Install drivers - Shut down computer completely - Connect Firewire 410, switch power on - Restart computer ... nothing No "new hardware found". I have tested this on 2 different computers and get the same results. The power LED on my device is a quick consistant blinking. Anyone? Please? (I am a very experience user. Long time Pro Tools LE user (001, 002, 002R, Mbox) and Computer Science graduate.) |
Re: Installation problems
And nothing shows up in the Hardware Manager?
If not I would say defective device, cable or port. Unless your Plug and Play service is disabled. |
Plug and play is up and running. Both my iLoks showed up. Tried multiple cables and multiple ports (and multiple computers).
Bad device? |
The FW 410 may be defective. Did you talk to M-audio tech support?
I haven't contacted them yet. I wanted to see if anyone had any ideas first. Thanks.
well, i was gonna help you tell you admitted your a CS graduate ;-) .. j/k ..
i'm a techgeek too. i think that flashing LED is not a good sign. i've got a FW1814 .. the power light comes on ..as the computer boots .. all LEDs light, go out .. and then each led lights in-turn in a pattern. the only time i get a flashing LED is when it can't find a word clock (sync problem with external clock). i assume you've used your FW interface for other devices? i'd start simple ... and eliminate the obvious .. bad cable, power, firewire interface, etc. a bummer for sure.. ;-( jeff |
Thanks. Tried multiple cables, fw cards, computers, etc.
Looking like a bad FW 410. |
that's a drag .. it's first time i've heard of M-audio
stuff showing up DOA .. ;-(.... best wishes on the return rigamorro |
Installation problems | Mickstape Productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-15-2009 01:11 AM |
Installation Problems...Please Help Me! | Chad Pippin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-28-2009 01:47 AM |
Installation Problems | inlimbo21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-30-2008 07:47 AM |
Installation Problems | MikePhilippov | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-14-2006 02:04 PM |
help please! installation problems. | jday | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-14-2005 08:14 AM |
