Does PTLE or MPOWERED support OMF???? natively?
I was reading a review about how only ptle will support digitranslator not mpowered.
but then i also read that ptle can open and save to omf (OPEN MEDIA FROMAT). Do you have to have digitranslator to use omf or do ptle and mpowered have the capability built in? i Also work in logic and nuendo and want to know if i have to fork over more money to move my sessions in between daws. |
Re: Does PTLE or MPOWERED support OMF???? natively?
From a previous post by Rail,
I wear the pants. (My wife picks them out) |
I was under the impression the MPowered does not support the DV toolkit, I think whats being asked here is.
Will MPowered support the OMF import option? and is that nessicary to import/export form Logic and Nuendo. PTLE and Mpowered do not have built in OMF support. You would have to purchase the rather pricy DigiTranslater option if you wanted to use OMF to transfer sessions. I don't use Logic or Nuendo so I don't know what their Import/Export options are. You may not need OMF to transfer between the 2 and PT. As far as I know there isn't any reason you can't use the DigiTranslater with MPowered. You might check becuase I think one of the Academic versions of Mpowered had either SMPTE support and OMF import capabilities, If your a student that could save you a lot of money. EDIT I see the DigiTranslater is no longer available as a separate purchase.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Closest thing to HEAT possible Natively? | DUCHUNTER | macOS | 27 | 06-16-2014 01:36 PM |
Importing PT, Natively, Into Final Cut Pro | dBHEAD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-04-2011 07:47 PM |
PT HD 9 running natively ADC not working. | mgoorevich | Pro Tools 9 | 24 | 11-13-2010 03:03 PM |
Does MPowered 7.4 support OMF via DigiTranslator 2 | capitala | Pro Tools M-Powered (Mac) | 1 | 07-24-2008 09:14 PM |
PTLE & MPowered in Same MacBookPro | tikboy | Pro Tools M-Powered (Mac) | 1 | 08-29-2007 07:14 AM |
