PT8-Goes into pause, not play
Just upgraded to 8.
When I hit space bar or play/stop, usually goes into pause rather than play. What's the trick this time? Q6600, 4gb, QuadroFx, etc', all working on 7.4 |
Re: PT8-Goes into pause, not play
This happens for me in 8.0 at 64 buffer, but not 1024.
Cheers,
Hey Bruce.
Looks like we have the same gripes! Yep, all lower buffer sizes, not the higher ones. Is this still an upgrade? |
I used Acronis to roll back to 7.3.1cs7. For me, whatever I would gain in 8.0 is negligible for what I do. I'll try any cs updates and see what, if anything I've posted regarding the jump back cursor problem and the Tech Support Utility v2 gets fixed. And like you, I'd appreciate an option to go back to the now Pro Tools Classic GUI we're all used to.
Cheers,
7.3
Ahhh... yes the infamous Play/Stop (Pause) Transport issue, unlike Bruce, I encounter this at a 1024 H/W, 3 RTAS and 1 Offline Processors, 85% CPU with /3 GB LAA (MIDI). Ummm... solutions, you might like to try the Pro Tools configuration above, Bus Record MIDI and Inactivate. Close Plug-In windows, that is minimize Pro Tools duties. Other workarounds, roll back the Graphics Driver or Update. ...and I'm open to solutions! filosofem |
fellas, i'm not in the studio right now but i'll see if i can make some sense with my suggestion. go into DAE playback preferences and set the 'disk' performance from 'default' to 2 or 1. i'd say gauge it dependin' on your disk cache size. tunin' this setting along with makin' sure your 'record allocation' time is NOT set to 'use all available space' should give you a better response when pressin' play. make sense??? sorry i'm not in front of PTLE to give a more accurate description
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
mykhal c long time no talk, 1500ms Level 2 is Default which for myself is where it stays however Cache Size is set to Large with a non-open ended recording allocation. These are my defaults by the way.
filosofem |
what up filo. happy holidays brah. yep, set your level to 0 for disk and i 'think' i set my cache to whatever gives the highest performance. i'll check 'em tomorrow to make sure
...and to you. Disk Latency reduction is related to MIDI RAM-Based VI's?
I'll test 400ms filosofem |
Trying to Get Around the PLAY/PAUSE Bug | Kbiastre | macOS | 0 | 03-12-2012 02:26 PM |
Pause/play bug in PT10 | DanDeurloo | Pro Tools 10 | 10 | 11-11-2011 01:06 PM |
What Did I Do? Play/Record has a pause .... | Craiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-02-2009 03:43 PM |
"Play Pause" mode? | bfoster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-29-2007 02:09 PM |
Play and Pause Together? | LeonD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-15-2004 10:55 AM |
