Old 07-14-2008, 10:49 AM
howie300 howie300 is offline
Default playback looping error
Hi all, I'm running HD 7.3 cs6 on a PC... am enjoying the power of core 2 quad! but am experiencing some problems which are starting to get annoying:
have any of you experienced looping playback? i mean, the drums will suddenly go back a couple bars while the rest of the song continues playing, so the effect would be the song not aligning. sometimes when tracking vocals, the singer would say something, and it'll only playback after a couple seconds, and i wasn't even recording. now it's starting to cause the bouncing to fail, because the looped playback of indiv. tracks will be recorded into the bounce... very strange indeed. have anyone experienced this? thanks in advance, it'll really help me out!
howie
Old 07-14-2008, 04:33 PM
x9blade x9blade is offline
Default Re: playback looping error
similar but not exactly the same problems over here. i will sometimes getglitchy audio and if i press stop the session will continue to play for a few seconds. i have also had the out of alignment at times.
what mobo are you using?
i get these issues on certain sessions occasionaly.i'm running 7.4 cs 5
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
Old 07-14-2008, 06:14 PM
I've only had this happen when using VI's
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 07-14-2008, 10:39 PM
using vi's here. been dealing with this problem every now and then since i built my intel q6600
Old 07-15-2008, 02:34 PM
i'm using the asus P5E WS professional MB. running PT 7.3 cs6. but i don't think the cs updates helped at all. it has the same problem with just 7.3. I guess now I know it doesn't help upgrading to 7.4 either.
Old 07-26-2008, 01:33 AM
psmworld's Avatar
psmworld psmworld is offline
Default
i´m on 7.4 cs5
i get this problem mostly with duende-plugs.
i set the dae playback buffer level to 0 or 3, where level 0 is more stable here.
disc allocation set to fastest.
Old 07-27-2008, 05:18 AM
Default
hmm, it seems whichever buffer setting I choose, the looping problem remains the same. i hope it's not an MB choice problem, but that might be the culprit..
Old 07-27-2008, 05:31 AM
psmworld's Avatar
Default
which interface do you use?
which plugins are in the project? rtas and tdm or one kind of them only? have you tried the session with inactived plugs?
buffer settings most stable are 1024 at 96khz and 512 at 44.1/48khz. this shouldn´t be changed.
send me your main-setup including pc-hardware, i´ll look into my test-chart for a problem.
Old 07-28-2008, 12:41 AM
Default
oh ok, I'll send the specs as soon as I get to the studio. strange thing is, it happens even if I don't use any plugins. minimal tracks, i tried recording with 1 mono track plus a master track opened, and it still happens.
Old 07-28-2008, 02:42 AM
psmworld's Avatar
Default
also look for the card order on the motherboard. this is very important for me to look at.
turning looping on and off during playback? George DAWs Tips & Tricks 1 12-09-2013 10:49 AM
Playback and Looping Issue in PT 7.3 tikki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2007 09:38 PM
PTLE 7.1 PLAYBACK NOT LOOPING djpledge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2006 11:40 PM
Looping vocal while monitoring music playback dougpotter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-10-2004 12:28 PM
Loop playback not looping Bixby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-16-2004 10:00 AM
