Windows 10 | Drag&Drop from Soundbase to Explorer & other Software
I saw the latest 12.7 update and the new shiny library management system. Since this seems one of the best, I got interested in buying Pro Tools. However I use other DAWS as well and would like to use Soundbase for all of those DAWs. Is it possible to Drag & Drop audio files from Soundbase into other applications on Windows 10? Is it possible to run Pro tools and other Daws at the same time? Thanks a lot Jason |
Re: Windows 10 | Drag&Drop from Soundbase to Explorer & other Software
Hey Jason,
Currently, Workspace doesn't support dragging files outside of Pro Tools. So, this wouldn't really work in the workflow you've described. That would be an interesting feature though. What you could do is use Soundbase to search for files, then right-click on them to "Reveal in Explorer", then drag them into the other DAW. More steps than you probably want, but that would be one way to do it. And, yes you can run Pro Tools and another DAW at the same time. However, if you're using the same audio interface you want to make sure both DAWs are at the same sample rate.
Kyle Splittgerber Senior Principal Product Designer Avid Berkeley, CA |
Thanks a lot for your answer !
I spend a lot of time with sample browsers and their feature set over the last weeks. Pro tools is seems to provide the best experience in this regard. Maybe its in your interest to sell Soundbase as a separate product as well? The workaround lowers fast paste working and reduce productivity, I guess. Seems like I need to wait a bit more until a universal browser is available cheers Jason |
From my experience, if, as per Avid's Windows optimizations, you "Run As Administrator" for Pro Tools, you can't drag-and-drop to the timeline.
Drag and Drop Windows issues... again... | noiseboyuk | Post - Surround - Video | 9 | 09-03-2015 10:08 AM |
Transfuser audio Drag & Drop in Windows 7 pro? | docric | Virtual Instruments | 13 | 04-21-2015 09:39 PM |
Windows 8 Drag and Drop not working | notedmusic | Windows | 1 | 01-23-2014 09:18 PM |
How to drag-and-drop in Windows | colourednoise | Windows | 3 | 07-12-2013 01:53 PM |
Windows Explorer drag and drop audio files to PT8.0.3 | Buccanears | Pro Tools TDM Systems (Win) | 9 | 03-20-2010 09:05 PM |
