Old 08-19-2013, 08:25 PM
2crows's Avatar
2crows 2crows is offline
Default exporting ?
hi,
i am trying to export a single track as a mp3,
does anyone know where i can find this info,
thanx
Old 08-19-2013, 08:56 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Default Re: exporting ?
Did you try it by the book already? Is there an actual problem or are you asking to learn?
Then.. There's too little information about your system/setup and problem in your post. For example: Are you talking about Pro Tools 11.5 beta .. or CoolEdit 95 perhaps. ;-)
Just kidding. Just give us more info!
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
Old 08-19-2013, 09:39 PM
Search the help files for "exporting audio"
Old 08-19-2013, 09:51 PM
FLi's Avatar
FLi FLi is offline
Bounce to Disk
Old 08-20-2013, 08:19 AM
With PT10 and 11, you can simply Export Clips as Files...with older versions, the MP3 feature was an option, so Export as a wave and convert with any of several free converters(WMP and iTunes included).
Old 08-20-2013, 11:31 AM
2crows's Avatar
thank you all,
i posted to learn, i had looked at the PT helps, must have been in a hurry because i missed the xport audio,that explained it, its good to know what to look for.
I am using PT 10.3.7
11 rack as interface
win7 ult 64 sp1
Alienware laptop
i5 520m @ 2.40ghz
4.00gb ddr3
thanks agian for your time
Old 08-20-2013, 01:41 PM
2crows's Avatar
when i bounce 2 disc the file shows up but will not play in either itunes or mediaplayr, attached are my settings for the bounce, i have looked at the help files and follow the directions to the best of my ability, any suggestions,
thx
Old 08-20-2013, 01:45 PM
YYR123's Avatar
YYR123 YYR123 is offline
thx
Try bouncing to interleaved stereo
Daniel
Old 08-20-2013, 05:31 PM
+1 for interleaved. Then there's the sample rate. Are you recording at 16 bit/48K? Recording at 24 bit is a better idea(and then dither if you need to go to 16 bit for CD audio, but you would also probably need to go to 44.1K as well). BTW, when you export from Pro Tools, if you have a 24 bit session and are exporting to 16 bit, PT automatically applies dither(if you Bounce to Disk and want a 16 bit final from a 24 bit session, you should use a dither plugin as the final insert).
Old 08-20-2013, 06:52 PM
2crows's Avatar
I can set the sample rate at what works best for itunes, all i want to do is export 1 or 2 trax as mp3 for now, i just want to upload the file that will play in itunes, i am taking online guitar classes and need to send lessons.
I would like to learn more about PT later down the road but for now its just a strait ahead lesson file so any suggestions about what i should set the export rate and the record rate for this purpose would be of great help.
i appreciate the fact that u guys have spent time and money on your skills,( much respect),
i don't mean to come off like i want something for nothing"hep me, hep me,i got a broken wing" and don't want to put in the time, its just that i need to get the basic Record xport function down for my classes.
peace!
Exporting an OMF from P.T DrDub Post - Surround - Video 3 01-15-2008 10:58 AM
exporting a 24/48k to a 24/44.1k PMoshay Pro Tools TDM Systems (Mac) 0 04-24-2006 11:09 PM
exporting omf canoa Digidesign Hardware & Software 0 04-24-2002 08:31 PM
exporting from PT taccomc Pro Tools TDM Systems (Mac) 1 04-26-2001 06:12 AM
Exporting an EDL mechanic Digidesign Hardware & Software 0 01-26-2001 08:27 AM
