Old 06-24-2004, 05:12 PM
Larry Pate Larry Pate is offline
Default Dual G5 with dual hard drives
Thinking of getting a G5 with two hard drives, one for OS and the other for recording audio in lieu of seperate firewire drive. Will this work? 002, PT6.4, OS 10.3.4., Reason 2.5.
Mac mini 1.42, 1G Ram. OS 10.4.11, Digi 002, PT7.4cs1, LaCie d2
Waves Musicians Bundle, GTR, ST2x, Reason 3
Old 06-24-2004, 05:21 PM
nightshadecrisis nightshadecrisis is offline
Default Re: Dual G5 with dual hard drives
that would be a smokin' hot computer. this is the windows side though, try the mac....and...check out the "Best Desktops for PTLE" forum above this one.
e
v
ik zei nooit dat!
Old 06-24-2004, 06:03 PM
Thanks. Wrong Button!
Old 06-24-2004, 06:14 PM
The Weed's Avatar
The Weed The Weed is offline
Do check out the "Best Desktops" thread, but only if you want to save a half to two thirds the cost of a G5 with a comparable-in-performance PC. Please note, I said comparable-in-performance not comparable-in-hardware. Most Mac people want to make a comparable-in-hardware comparison when the issue of price comes up. A fully tricked out, dual Opteron is not much cheaper than a comparable-in-hardware dual G5. However, a dual Opteron is not necessary to get the same performance in PT LE as a dual G5. Some of the Centrino laptops are the equal of or slightly better than a Mac dual G5 when it comes to PT LE performance. See this post. YMMV
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 06-24-2004, 10:36 PM
Bastiaan Bastiaan is offline
but there are still more plugins available for the mac, although its rappidly changing
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 06-25-2004, 05:47 AM
lemix's Avatar
lemix lemix is offline
...plugins, schmagins...
It's all aboot ( ) supporting Mr. Gates's crumbling little empire...
Buy a PC !!
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Dual Hard Drives? Why? Jasconito 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-03-2011 08:01 AM
Internal Hard drives for G5 Dual 2.7GHz toneski Pro Tools TDM Systems (Mac) 8 04-07-2008 08:02 AM
computer lag, dual hard drives, help please tbonechillaxin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-02-2006 04:38 AM
Dual G5 with dual hard drives Larry Pate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-25-2004 08:34 AM
Dual hard drives Jonah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2003 12:36 AM
