Will PT10 work with an HD set up or do you need PTHD10?
Hi!
Forum newbie here. I'm currently looking into my upgrade options for PTHD7.4 (yes I know its old - but very stable) and am looking to shift to PT10. Any direct correspondence with Avid hasn't helped me to make a decision on this The present upgrade cost to PTHD10 is prohibitive but the jump to PT10 is not so, can I do this in the interim period? Will I function ok with a HD system and legacy interfaces? Any help or advice would be most welcome |
Re: Will PT10 work with an HD set up or do you need PTHD10?
You need HD to use the TDM cards and plugins of course and be able to acces all the HD features and i/o capabilities. running non HD you will have only rtas plugins, limited features campared to HD and only 8 i/o using core audio. Chris
Thank you Chris
I was aware of the TDM plugins being an issue but not the i/o limitation. Is this just with legacy interfaces or more recent ones too? |
I think it's with legacy interfaces. This would be when using the TDM system with Logic, etc.
As mentioned, the TDM system won't work at all with non HD Protools, so you would need to use some other type of interface. Also, I'm sure you're aware, but there's not an actual upgrade from HD licenses to non-HD licenses. You would need to just buy a full version of PT10 (now 11), or buy an interface bundled with it, like the Mbox Pro or Eleven Rack. It's actually cheaper now to get an Eleven Rack bundled with Protools, than it is to just buy Protools. |
So - I went for the non-tiered upgrade (which gives you licenses for PTHD 10,11 & 12)
I first had to buy the upgrade to PT8 HD. Very happy with PTHD 10! Can't believe I didn't make the jump sooner! |
Will the PC work with PT10 (non- HD version)? | Dopamine | ProControl, Control|24, Command|8 | 8 | 09-18-2014 10:30 PM |
From PT10 CPTK to PTHD10 and PTHD11 | yanos | macOS | 2 | 11-18-2013 01:22 AM |
When Will PT10 Work with Windows 8? | ianbee | Windows | 7 | 07-15-2013 09:13 AM |
PT10 help please , does PT10 really work on win 7 (digi support please) | digi003 | Windows | 6 | 02-01-2012 06:36 PM |
PT10 m-powered work with old G5 Mac? | stevedresser83 | macOS | 3 | 12-06-2011 07:40 PM |
